Question about Brother DCP-7065DN Thermal Barcode Label Printer
How to print bar code with brother dcp-7065dn
How to use barcode label printer
Mix-it-up
  • 832 Answers
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Posted on Mar 29, 2008
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
komguy
  • 2306 Answers
SOURCE: my Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
Posted on Jul 22, 2009
pineworks
  • 4041 Answers
SOURCE: brother printer dcp 330c - unable to print 50
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
n1wgk
  • 84 Answers
SOURCE: nozzle clogging on the Brother DCP-165C multifunction printer
take swabs and use alcohol to manually clean it...GENTLY and with not too much alcohol. You will go through several swabs. Use the foam swabs, not cotton, so you don't leave junk behind.
Posted on Mar 07, 2010
BROTHER DCP-7065DN HOW TO REPAIR LEFT SIDE VERY LIGHT PRINTING
When this occurs it usually means that the toner cartridge is running out of toner on that side. The left is most common since most printing is on that side. Remove the toner cartridge, and shake it vigorously from side to side for a few second, then replace and try again..
Apr 14, 2015 | Brother DCP-7020 All-In-One Laser Printer
71 print unable error
Clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip behind the printer head
Mar 08, 2015 | Brother DCP7065DN DCP-7065DN Multifunction...
Brother dcp 7065dn are problems print unable EF
Check the ventilation fan on the side. Might not be working. Remove any foreign material blocking the fan.
Dec 07, 2014 | Brother DCP Office Equipment & Supplies
Printing 4 x 6 cards
Set the layout to 4 x 6 in your software. When you are finish, go in printer preferences and select 4 x 6 in the page layout.n Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 24, 2014 | Brother DCP7065DN DCP-7065DN Multifunction...
How to configure Brother DCP-7065DN to scan directly to Synology DS412+
I don't believe the DCP-7065DN allows scan to FTP. Brother's models MFC-7460DN and MFC-7860DW do provide this function. Good luck and please share your solution should you find one.
Dec 31, 2013 | Brother DCP-7065DN MFC / All-In-One Up to...
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Brother DCP-7065DN Thermal Barcode Label Printer Logo
13 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
