Where can I get the hose for my 9000 BTU continental electric ax
2 Suggested Answers
  • 2006 Answers
SOURCE: I have two Contintenatl Electric
You might want to take one of the hoses into an auto parts store and get the heater hose tubing for a car. Then wrong the close in ends with aluminum tape to reflect the heat away from the hose.
Posted on Jul 22, 2011
What is the BTU of modelM6FQ10F2A
the btu rating will be on the same plate as the model number
if there is no btu rating but a kw rating then there are conversion tables to work it out
for example a 2kw unit is close to 9000 btu and a 8kw unit is around 32000btu
May 23, 2015 | Heating & Cooling
115 volt equals how many btu
Apples and oranges.
The 115 volts tells what "quantity" of electricity is needed to run the unit.
BTU's are the cooling capacity of the unit, which usually is about 5,000 for the smallest, up to about 18,000 for the largest.
Over 18,000 the electricity quantity is often boosted to 220 volts because of the larger size of the unit.
Jul 02, 2014 | Continental CE-PAC1062 Air Conditioner
My aircon is not blowing
Most liekly needs to have freeon added to the system, if that doesn't help its propely a problem with the electric motor on the blower.
Nov 07, 2012 | Gree 9000 Btu 23 Seer Ductless Mini Split...
Hi, how to you add more freon to 9,000 btu fugitronic portable a/c? Thanks
From the condensing unit you can see two valves. Connect the blue hose to the bigger pipe sometimes marked "S" to the suction manifold gauge with the blue dial.The discharge valve "D" is the smaller pipe and connect it to the red hose going to the red dial gauge. After connecting the hoses respectively, open the blue handle of the manifold to release air from the blue hose and close it. The same thing should be done to the red handle valve of the manifold. Connect the yellow hose to your freon cylinder and slightly open the cylinder valve while connecting it to the middle of the gauge manifold. Now, there is no air from all hoses and you can start charging freon when the unit start running. Check suction pressure and the Rated Load Ampere of the unit
Sep 03, 2011 | Fujitronic FA-9000 9,000 BTU Manual...
I have two Contintenatl Electric 9000 btu units, and on both of the the hose and the piece that connects and seals the hose to the back of the unit is split open. Duct tape has not worked well, given the...
Jul 22, 2011 | Continental Electric Portable Air...
Need part number a5815-090-h-bs this is the window adaptor for the hose connection. AC portable 9000 btu. lost the window plate/adaptor. need to replace it.
did u find the adaper for the Maytag M6PO9S2A? I found one but not sure if its the right one as I also have the same portable air conditioner
Jul 07, 2011 | Maytag NMPEB08F2A Air Conditioner
My 9000 Btu Kenwood Continental Series split unit shuts down compressor after every 10-15 minuits regardles of room temp. Gas pressure is OK & I have tried replacenig cooling sensor but to no use. I am...
Sounds like the compressor may be overheating. You need to check the outdoor condenser coil it may be stopped up with dirt, in turn, overheating the compressor. The condenser coil looks like a radiator and the outdoor fan blows through it, in a sense releasing the hot air from the building. If the coil is stopped up, it can not release the heat. You can wash this coil out with a hose and sprayer. Just be careful not to get the motor wet and be sure to shut off power.
Jun 24, 2011 | Kenwood Heating & Cooling
Need a owners manuel for haier air conditioner 9000 btu
To help you with the correct Owners Manual, I will need the correct Model Number for your Haier AC Unit. They make 3 different models for 9000 BTU.
Please advise. Thanks.
Jun 08, 2011 | Haier Heating & Cooling
We have a 9000 btu portable frigidare air conditioner, we are constantly having to manually drain the bucket even with drain pump hose attatched. Is it possible tat the drain pump is broken? Occasionally...
Wow maybe you have a lot of moisture in the air.
It is a strong posibility the pump has trash in it. periodically clean out the pump for best results.
I realy have never even seen a 9000 btu portable ac or worked on one. Just guessing.
Jun 25, 2009 | Frigidaire FAP094P1Z Portable Air...
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
