Question about Zebra P110i Led Card Printer
Zebra P110i Led Card Printer won't print black
SOURCE: Zebra Card Printer P310
Chris,
It sounds like you have a blown pixel on your print head and will need to have it replaced. We are a full-service Zebra Reseller with factory-trained staff (former Zebra techs) and can easily take care of that for you.
If you are still looking for repair, please contact us at your convenience.
Posted on Sep 03, 2008
  • 185 Answers
SOURCE: A pc on our network can print to networked
Check the drivers are correct for your machine, also check the port your using is suitable
Posted on Apr 13, 2010
SOURCE: Cleaning my ID Card Printer
http://www.youtube.com/watch?v=CzGXjl4Rv1
Posted on Apr 27, 2010
news775
  • 699 Answers
SOURCE: Is there a Macintosh driver for the P110i led card
No
Please dont forget to vote if you liked my answer
thanks
Posted on Feb 08, 2011
fxurikfx
  • 20 Answers
SOURCE: Zebra P110i printer is making a noise when cards
Check the type of cards you are using, they might be too thick. If you are using the regular 30mil PVC Cards then make sure before you load the cards you "fan" them, meaning try to separate the cards as when they build static electricity and "glue" to each other.
If that does not solver your problem, then you should send the printer for repairs, check your warranty status with your ID Printer Vendor.
Also, sometimes if you are using the Adhesive cards, the paper back of the card does not feed into the roller system of the printer.
-- The Pros at www.DiscountIDStore.com
Posted on Feb 10, 2012
When I try to print multiple cards, only 2 cards print, the same two all the time, the others don't
It sounds like you might have a job stuck in the print-queue. Best way to check is to start with a clean slate:
1. Shut-down your badge-software, and disconnect the printer from its power source;
2. Navigate to the Windows print center - accessible from the Control Panel as "Printers & Faxes" if Windows-XP, or "Devices and Printers" if Windows 7.
3. Right-click on your Zebra P110i printer, and select "See What's Printing" to open the queue, and see if there are jobs there. If so, click "Printer" on the menu, and then "Cancel all Document".
4. You also should ensure that you don't have any additional instances of the printer drive installed - they would show up as Zebra P110i (Copy 1), ... (Copy 2), etc. This occurs within Windows if you've disconnected the PC-end of the USB cord, and then plugged into a different USB port than originally used. If you have multiple instances, the easiest way to clean this up is to right-click on each sequentially, selecting "Remove this Device". Do this for each one.
5. Now you have a "clean slate". Connect the Zebra printer to the PC's USB, and then re-connect the power. If it doesn't power on, push the power button so it is on.
6. WAIT until Windows recognizes the pritner and you see the device is ready to use.
7. Open your badge software, and select a single card to print, and send it to the printer. If all goes well, this single card will print correctly, then the printer will come back to a ready status. Repeat for a second card, and make sure it prints correctly, and comes back to ready. If all is good, you've likely cleared the issues up, and you can proceed normally. If not, then there may be a physical problem with the printer, where it is not recognizing that a finished card has been ejected and the job is done, or it's not communicating that "done" status back to the host PC.
Feb 07, 2015 | Zebra P110i ID Card Printer
Zebra P110i printer is making a noise when cards are feeding through to be printed and sometimes says Mechanical error. Print quality is fine but, cards occasionally do not fully drop out when print job is...
Oct 11, 2011 | Zebra P110i ID Card Printer
Cardfive can not find the zebra printer p110i
On your cardfive configuration for the printer, there might be 2 printer drivers in the drop-down list, you might have the wrong one selected.
Oct 10, 2011 | Zebra P110i ID Card Printer
My Zebra P110i is not printing it's cards correctly, When I print a card, there is always a 2mm blank line gap on the end of the card where the printer has not printed on it. I've cleaned the printer,...
The Zebra P110i printer is an Edge-To-Edge card printer, which means it will print on the card closest to the edge as possible, however there will still be a slight line. Although a 2mm line is too big, should be no more than 1mm, there will still always be a line.
There are some advanced EC (end card) settings that could be adjusted but if the print goes too close to the edge, the ribbon will get cut.
Mar 26, 2011 | Zebra P110i ID Card Printer
Is there a Macintosh driver for the P110i led card printer?
No
thanks
Feb 08, 2011 | Zebra P110i Led Card Printer
Zebra p11oi will not print anymore
Make sure you have the ribbon set right in the driver. If the driver says ribbon X, and the printer is loaded with printer Y, it won't print. (Make sure any driver settings are done while logged in with Windows Admin rights - "regular" users don't have sufficient privileges to make driver settings changes).
Also, check the printer queue and device settings. Make sure there are no jobs stuck in the queue ("Cancel all documents"), and make sure the printer is NOT set to "Use Offline" or "Pause Printing".
Other than these items, it could just be that the printer has lived its life and ready to be put out to pasture. Feel free to contact us for other questions, or to consider replacement options.
Jul 26, 2017 | Zebra P110i Led Card Printer
Zebra P110i Led Card Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
