Akira tv with one line more than half of the screen...and within 5 seconds the line is going too much bright.
    Top Expert:
  • Televison & ... Master
  • 75,424 Answers
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel is given. You can see it and compare to that of your TVs' and can make confirm.
Posted on Apr 16, 2014
3 Suggested Answers
  • 8457 Answers
SOURCE: There are vertical 1
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Posted on Apr 04, 2010
SOURCE: The TV keeps going to the MENU on it's own...When
Hey djames1971 - did you ever get this resolved? My Philips is doing the same exact thing now; sooooo annoying. If I keep monkeying with the exit setting it eventually goes to the TV and stays there, but it doesn't fix it by any means. Next time I go to turn it on I have the same battle with it.
Posted on Jun 28, 2010
What is the meaning of the name akera
  1. Akira (???, ??? ?) is a common Japanese given name. There are several kanji for Akira. A popular kanji is ? which means "bright", "intelligent", or "clear". Though Akira is normally used to name males, it can be a female name as well.
Gopakumar Gopalan Google
Nov 30, 2014 | Miscellaneous
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
Mitsubishi VS70707 Has developed subtle lines in picture
If they are faint white lines, they are called re-trace lines. They are caused when the current to the CRTs is too high. One way to check is to turn the brightness down. They should go away, but if the picture is too dark, you will need to turn down the "screen" control. This will take some handy work. If you are handy enough, take the grill off the front. Inside you will see a little black box, about 5 inches wide. there are 6 knobs on it, 2 for each color. One row is for focus (each) the other for screen (brightness). It is written on the part. The trick is to turn each of them down equally or risk having a slight tint of color. Really not hard at all, but requires the TV to be on to see. You shouldn't need to turn it but a fraction. Good luck.
Feb 16, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Whistling problem
What you can hear is a coil on the main line timebase board resonating at half line frequency, about 7.5k and 15.625kHZ or whatever the line frequency is in your country. Nail varnish on the coil will usually cure this.
Apr 18, 2017 | Panasonic CT-32SL14 32" TV
Problem with AKIRA TV
i need akira tv service mode code pl help me
Jun 23, 2008 | Akira SV-4201 42 in. Plasma Television
The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Aug 30, 2007 | Televison & Video
Top half of screen black
The vertical circuit is going bad,this is the one in charge of opening the picture up and down,try taping on the side to see if the picture reacts ,if it does your set has a loose conection and the vertical IC will need to be resoldered only but if it does not react the IC will have to be replaced,if you are familiar with tv service this will give you a place to start but if you are not be safe and seek the help of a servicer,please let Us know how it goes.
Oct 11, 2006 | Sony KV-XA34M66 34" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
