Question about GE WJSE3110A Top Load Washer
Washing machine not spinning
My washing machine is not going round.  It fills and empties as normal but will not spin.  I tested it with an empty load and it spins as normal.  Any help would be much appreciated.  It is a Siemens Siwamat 2105.
GE Super Capacity Plus 11 cycle Heavy Duty Exclusive Auto Balance System Quite By Design Mod. #WJSE3110A2WW washing machine will not spin out water from clothes. washer spins very slow, can smell rubber burning. I know it is a belt or a small rubber motor coupling and or motor isolation. Had the same problem years ago but with a Whirlpool. I have not taken it apart to see yet. Was trying to find a manual first. THANKS
  • 790 Answers
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Posted on Nov 02, 2007
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
Top load washer filling, emptying but tub not oscillating or spinning. Motor sounds like it is running fine. Colin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 27, 2010 | GE Washing Machines
It fills w/ water,and empties it wont spin ,or agitate
heatman101
Sep 06, 2010 | Washing Machines
Washing machine fills with water ok but won't agitate completely, will empty the water but will not spin.
heatman101
Aug 29, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
My washing machine fills up but does not wash it just keeps filling and empting what could be wrong with it?
controller is stuck be the sounds of it. spin it round a few times.
If its filling at the start and then emptying when it would normally finish, then check the belt has not broken or the motors brushes haven't worn out.
It's not a direct drive machine is it? if so get a technician in
Jan 11, 2010 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Zanussi washing machine
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
check for a capacitor on the motor if it has one, replace that to start with, that what it sounds like
Oct 10, 2007 | GE Spacemaker WSLP1100D Top Load Washer
GE WJSE3110A Top Load Washer Logo
749 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
