Question about Topcon Rl-h3cl Long-range, Self-leveling Rotating Laser
No power nuw battery no power
    Problem Solver:
  • 5 Answers
Batteries have a shelf life even if they are not used. Try L&W Battery. www.batteryrebuilds.com
Posted on Feb 13, 2016
    Problem Solver:
  • 8 Answers
It could be a few things.
1. Bad keypad / power button ($30.00 and labor)
2. The power connection is lose from the main board.
3. Corrosion on the rear battery terminal.
4. Lose connection / Battery Springs
5. Bad Main Board.
Most of the time when a laser will not power on, it is a battery connection issue. You can carefully open it and inspect the wiring (red and black cable that goes to the green main board)
If the only problem is that it wont power on I'd be willing to bet it's repairable. Those units are notorious for not holding calibration. If you drop one chances are it may no longer hold calibration due to a bad compensator.
Any laser dealer with a service center should be able to pop that thing open and fix it pretty quickly
If you don't want to pay to have it repaired, open it and check the connections. Be careful not to touch anything unless you have an esd wrist strap, or you could damage the main board. At this point it's already broken so there is no harm in trying.
Posted on Jan 23, 2015
MY CAR DONT GO FASTER THEN 80 KM AN HOUR ALRADY PUT NUWE PLUGS AND RINGS AND TIME MING BELT AND A NUWE FULE PUMP .FORD FIESTA 14.00 1997 MODEL THE FIRST TIME IT OVER HEAT
check cooling system thermostat device called a thermostat it is a valve that puts more water into the engine when it needs it. it could be stuck on closed and not letting water into engine when needed
Jun 21, 2016 | Cars & Trucks
I have a 1995 c pick up put a nuw fuil pump and really in it pump is not pumping gas can I run a hot wire from the battery to it
Instead of rigging it why don't you lean how to fix it right . There are plenty of trouble shooting videos on you tube for GM fuel pump circuits . Watch scanner danners video GM fuel pump circuit testing , Also check out a basic electrical trouble shooting video . Go to www.bbbind.com/ for a free wiring diagram of your fuel pump circuit .
Nov 24, 2015 | Cars & Trucks
The valve is broken ware i buy e nuw for remplace
what valve does a slow cooker have that would need replacing
it is simply a ceramic pot with a temp controlled element in the case
Nov 07, 2015 | Crock Pots & Slow Cookers
Reset password
how do i reset my
password
Dec 16, 2013 | Computers & Internet
I need a nuw band
try this: www.razorreef.com
Oct 11, 2012 | Freestyle 91072 Navigator watch
Need step by step ways to fix my msn messenger webcam cutting out
if you get an era cod or a pur signal for it it may be your fayer woll i had the sam problum and i tornd my fayer wol of and youst the windos wone and it worksh fin nuw
Jun 23, 2011 | Microsoft Windows Live Messanger
94 pathfinder v6 auto 4x4 .engine died nuw wont start ,turns over and tries to fire,maybe the timing belt broke?if so would the valve train be damaged Thanks Barry
This vehicle has an interference engine (v6-VG30E), If the timing belt ran or snapped while running, its very possible the engine is severely damaged. Hopefully this helps!!
Mar 28, 2010 | 1997 Nissan Pathfinder
Topcon Rl-h3cl Long-range, Self-leveling Rotating Laser Logo
384 people viewed this question
Top Topcon Electronics - Others Experts
Are you a Topcon Electronics - Other Expert? Answer questions, earn points and help others
