Question about Breitling Watches
Hands will not move
Pulled out stem but hands will not rotate. New battery just installed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
Who installed the battery, are they competent?
If they are take it back to them for repair in not send it to Brietling service for repair.
This is not a DIY job.
Posted on Nov 10, 2014
SOURCE: Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Posted on Feb 22, 2008
HW_Dude
  • 87 Answers
SOURCE: analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Posted on Jan 10, 2009
  • 5 Answers
SOURCE: Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Posted on Feb 19, 2009
escapement
  • 2334 Answers
SOURCE: the hands are not setting themselves.
The controlling radio signal for the National Physical Laboratory's clock is transmitted on the MSF 60kHz signal via the transmitter at Rugby, operated by British Telecom International. This should have a range of some 1,500 km or 937.5 miles. All of the British Isles are of course within this radius.
The National Physical Laboratory's role as keeper of the national time standards is to ensure that the UK time-scale agrees with Co-ordinated Universal Time (UTC) to the highest levels of accuracy and to make that time available across the UK. As an example, the MSF (MSF being the three-letter call sign to identify the source of the signal) radio broadcast provides the time signal for, electronic share trading, the clocks at most railway stations and for BT's speaking clock.
Try to find a solution here:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Posted on Jul 23, 2009
  • 27 Answers
SOURCE: how do you move the hands of a casio 2747 watch [illuminator]
Below is the link for the manual with procedures to change both analog and digital time.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Posted on Oct 30, 2009
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
Mar 29, 2013 | Rolex Datejust SS
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
The sweep hands don't align back to zero after replacing battery
Pull out the stem to the second position then push the chronograph start/stop button a few times to move the minute hand to the zero position. Then pull the stem out to the 3rd position and adjust the second hand again by pushing the start/stop (top) button to move it to the zero position. Once you get them both to top zero push the stem back all the way and screw it in tight. Tim
Jun 21, 2010 | Watches
Watch does not work after changing the battery
mcdevito75 here, You can try, double check the battery instalation in the watch, If all is good, try to pull out the stem and move the hands as if setting the time, then push stem back in. It"s also possible you have a weak or even dead battery, even though it was bought new.
Jul 02, 2010 | Jules Jurgensen 7793IF ( ) : Swiss Quartz...
I cannot set the calendar for this watch...can anyone help me?
mcdevito75 here, Your watch (Timex) may have a 2 position stem. Push the stem (winder) all the way in, NOW just lift the stem a little to it:s first position, this should allow the date, (number ) to change, change that number to the date before the date you want, NOW pull the stem out to set the hands, rotate the hands to set proper date and time.
Jun 28, 2010 | Timex T Series Perpetual Calendar #T2M458...
Date set
The winding stem of the caravelle has two positions when pulled outward from the case. Pulling it full out lets you set the time. And, by rotating the hands through successive twenty-four hour periods it resets the day of the week. Pulling the stem halfway out allows you to set the month, but only if you rotate the stem in a counterclockwise direction..
Oct 03, 2009 | Caravell Bulova Caravelle watch
HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Nov 18, 2007 | Skagen 355LSSM Wrist Watch
Watches Logo
Top Breitling Watches Experts
Shehu Pro
Shehu Pro
michaelrt616
Are you a Breitling Watch Expert? Answer questions, earn points and help others
