Question about Numark CDN95 2-Disc CD Player
CDN95 WANT RIBBON REPLACEMENT - Numark CDN95 2-Disc CD Player
How to connect cd to amp
Line out phono plugs on cd player to "aux" in on amp, then select aux on amp
Apr 25, 2014 | Numark CDN95 2-Disc CD Player
Alright well I have a Numark rack mount dj set with two CDN95 2 disc players. Well I bought it used with speakers and everything and do not know how to plug everything, I really need some help please...
As shown in the Quick Start Guide (link below) this unit should be connected to a Mixer Unit.
http://www.numark.com/stuff/contentmgr/files/0/662529d8e9e5b8ebe1747274e5bad9d6/file/cdn95_quickstartguide.pdf
Looking at the Diagram they appear to be standard AV Cables so you should just be able to plug the CD Outputs into the Amp AV Inputs (as long as it's a Dual Amp) and then connect your speakers to the Amp (make sure the speakers impedance matches the Amp.
Further details available at http://www.numark.com/cdn95?tt=5
Please leave feedback
Cheers
Andy
Apr 25, 2011 | Numark CDN95 2-Disc CD Player
Cd not reading the music
Read this and decide if you or a pro should look at it...
http://www.repairfaq.org/sam/cdfaq.htm
Feb 03, 2011 | Numark CDN95 2-Disc CD Player
I like to buy the right side transport of my numark cdn95 player but i dont know where/
Your best bet is to contact Numark directly. I don't recall the optics used, but I think that this unit uses Sony optics. If the tray is not working correctly, it can be a belt or a mis-alignment. Ca you describe the problem you are having?
Dan
Jan 27, 2011 | Numark CDN95 2-Disc CD Player
Hello, How would I repair and find parts for a
What I do is first look on ebay for the same item in spares or repair. Buy it cheap and swop out the damaged/broken bits.
If that fails I download the service manual. Can take some google effort, but it can be found. By using the service manual, you will be able to repair and replace any part of your cdn95, assuming your not affraid of a little work and electronics.
If you are, then I suggest a visit to your nearest electronics repair shop is in order
Jan 06, 2011 | Numark CDN95 2-Disc CD Player
Hello i have the numark cdn95 2 disc cd player had a power outage in my home i did not have my numark cdn95 plug up to a surge and when i push the power button the buttons key lock light up and it wont...
Hi. Here is a link to a free download of your manual http://safemanuals.com/user-guide-instructions-owner-manual/NUMARK/CDN95-_E
Often times, a surge will require going into the machine and replacing one or two fuses. This is not an expensive job. Most all stereo shops have the capability to do this for a few dollars. Joe
Oct 21, 2010 | Numark CDN95 2-Disc CD Player
On my Numark CDN88s I have replaced both complete transports with brand new units and the cds still skip, and/or are fuzzy on playback or have disc errors. What am I missing? Is it a software issue, a...
Hi - may be a simple solution - Have the ribbon cables between the laser sony laser pickups and the main board been replaced - These fail 'very well' and can be impossible to see the brake
Apr 29, 2009 | Numark CDN95 2-Disc CD Player
While playing, Player 'freezes' so all functions fail
hmmm - slide the lid back and put a meter across the 3 power transistors that should be on the power supply board - seen from the top. (do this with the power off..:)) You may find once these warm up - which doesn't take long, they are breaking down
Mar 05, 2009 | Numark CDN95 2-Disc CD Player
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Numark CDN95 2-Disc CD Player Logo
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
