Question about Moultrie Game Spy M-990GI Scouting Camera
Tree movement takes numerous pictures
The slightest movement of my duck box by wind initiates the camera and I get pictures of nothing
When I take a picture, it blurs at the slightest movement. What setting is wrong?
Put the main dial on the green camera logo. It is the automatic mode. Then the camera will try to pick the fastest shutter speed it can use to make a good picture. When you take pictures in one of the manual modes, like S, A or M, or in night shot mode, the shutter time can be so long you have motion blur.
Mar 05, 2015 | Nikon Coolpix L330 20.2 Megapixel Compact...
I have a ViviCam X014N. Everytime I take a close up pictures, the images comes up fuzzy. What am I doing wrong? I follow Macro setting recommending 30-45 cm away, but still no luch.
Sounds like you're not using a tripod. Macro pictures have a very small area that can be in focus....the slightest movement can cause the blurry pics.
Sep 19, 2011 | Vivitar X014 Digital Camera
My camera takes blurry pictures it will only take clear pictures upclose
From my understanding the camera is VERY sensitive to movement and the slightest movement while the picture is being taken will blur the image considerably. This may explain why it can take decent pictures up close but not far away. The further away an object is when the shutter is open, the more exaggerated the distortion will be making it very difficult to take snapshots at a distance. The best thing to do is to simply try to stabilize the phone best as possible when the picture is being taken. It has an exceptionally powerful camera for a cell phone so it should take great pictures as long as it is held steady. Very steady.
Jun 17, 2011 | Samsung Memoir SGH-T929 Cell Phone
Hello. I am having trouble with blurred pictures when there is the slightest bit of movement in the shot. I think it's because I have the 'exclamation mark, hand shaking' icon on the back screen. Can...
It would be best to consult the user guide, you can download from here for free:-
http://fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-s7000-zoom/Support
I think its page 26 you need to check out, but it seems mainly to relate to taking pictures in low light, makes it harder for the auto focus to work.............try a tripod.
Dec 24, 2010 | Fuji FinePix S7000 Digital Camera
Focus problem. Coolpix 5000 mounted on Nikon microsocope for photographing tissue slides. Perfect digital images for years; now 90% poorly focused. Image viewed through microscope in perfect focus, image...
If you are initiating the shutter manually, it is quite possible that the camera has become very slightly loose at the F-mount. So, when you press the shutter button, the movement though it may be extremely slight, is shaking the camera at the exact moment you are taking the picture.
Make sure that the camera is tight to the F mount and that the F mount is secure to the microscope.
If you are initiating exposure via software, it is still possible that there is still some slight movement on your desk.
Remember, the slightest movement is magnified many, many times to the camera.
Dec 18, 2010 | Nikon Coolpix 5000 Digital Camera
Watch is new out of the box. Movement will not start. ???
mcdevito75 here, If your Wittnauer is a Quartz movement, look for a small piece of plastic, just under the crown (winder) remove this piece of plastic carefully and push the crown back down to start your watch, if it's an automatic movement, try to wind with the stem if you feel a resistance then winding will initially start yor watch by winding with 20--30 winds, if you feel no resistance when winding the simply rock your watch back and forth in your hand, you will detect something moveing inside the watch, this is the counter balance winding the watch, rock the watch back and forth for approx. 30 seconds to start an initial wind.
Jul 10, 2010 | Wittnauer Belasco 36 Diamond 27 Mm Watch...
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Camera taking pictures of nothing.
The sensor will detect movement up to 45 feet...If there are trees blowing in the wind it will trigger the camera...
You will have to relocate the camera position....
Jan 11, 2010 | Bushnell Trail Sentry 11-9200 Digital...
When I put numerous SanDisk SD Cads in my 450D it does not read them. What do i do ??
Are you trying to get your camera to read cards with pictures taken on a different camera? It doesn't work that way. If you're just trying to take pictures with the cards, just format them in the camera to initialize them. This will erase them so download any pictures first using a separate card reader if necessary.
Oct 16, 2009 | Canon EOS 450D Digital Camera
Pictures of nothing?!?!?!
had the same problem
is the tree you mounted it on too small?
the wind was blowing the tree i had mine mounted on and moving enough to trigger the camera
i cut the tree of about five feet up and havent had a problem since
also are there any branches in the way that may be blowing in the wind?
Jun 29, 2008 | Bushnell Trail Sentry 11-9200 Digital...
Moultrie Game Spy M-990GI Scouting Camera Logo
32 people viewed this question
Top Moultrie Video Cameras Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
