Question about U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel
E3 error code on wine cooler - U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel
2 Suggested Answers
  • 286 Answers
SOURCE: The door was not shut
e-5 means that the unit is 10 degrees warmer then setpoint. If you just close everything up and let it run the e5 should disappear when it gets within the temperature.
Posted on May 18, 2009
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
E4 code on display
E3 & E4 error code means problem with the connectors for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust.
Check the fan connectors by removing the two screws that hold the shelf in place and cafefully slide out fron the cooler. Just replaced the factory connectors with insulated bullet connectors.
Hope this helps; and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment.
Have a nice day and thanks for using FixYa.
Jose.
Oct 17, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
Samsung wine cooler rw13ebss e3 fault all iced up
I am sorry to hear regarding the trouble.
This is a common problem on this model and unfortunately, there is nothing you could do other than unplugging the unit for few minutes, say 15 minutes and then turning it ON. This would usually reset the error code. If the problem still remains, then it is either bad thermal sensor or whole digital controller.
If you wish to repair, revert and i would be glad to provide few more inputs to the diagnosis.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 11, 2011 | Samsung Freezers
Error Code E3 displayed on Samsung wine cooler model RW13EBSS, even after power off and reset.
"E3" on display for upper zone - error of DC
electric fan for upper zone.
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to each other. E3 went away and the cooler is working as it should now.in
Jun 15, 2011 | Refrigerators
Received apparent error message "E3" for upper
E3 is a fan error. This is usually caused by poor connection to the fan. Remove all connectors and reinstall assuring tight connection. This should remedy it unless the fan is bad, which is very rare!
Jan 12, 2011 | Magic Chef MCWC44DZ Wine Cooler
I am getting an E3 Error message on my temp
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
Feb 06, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
E3 error code on my Magic Chef Wine Cooler - what does this mean? Not sure of the model # but its only 1.5yrs old...Thanks!
could be a broken fan, compressor gone, thermostat. neither one you can fix. you need a refrigeration mechanic or a new fridge
Nov 11, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Jan 04, 2009 | Refrigerators
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel Logo
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
