Question about Crafts & Hobbies
Kw transformer power indicater lamp will not light even with new bullb
Not sure if circut beaker is working bought this used the tramsformer
Marrie
  • 563 Answers
SOURCE: The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Posted on Mar 27, 2008
  • 171 Answers
SOURCE: baumatic hood bt82.1 lamps blown..
Hi johnnyi6,
I'm Harvey the Master Plumber.
Your problem is: had a crackling noise then pop..looks like transformer has blown,replaced
but still no lights ..fan o.k...don't appear to be getting any power to transformer via switch?...how do you get push button switch out?...
bypassed light switch and lights o.k with new transformer..any ideas..
Yes, I agree, the switch went bad. It snaps in so you will break it during removal. I recomend you get the replacement switch first so you don't have a wire hanging out while you wait for the new one.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
  • 184 Answers
SOURCE: lamp has been replaced but TV wont power up?
If the lamp is a known good one, the next most likely suspects are the lamp ballast/power supply board or a mis-aligned lamp door. There's an interlock switch which opens when the lamp door is removed. Try removing and re-installing the lamp and the door.
Posted on Feb 15, 2009
SOURCE: hi, my projector has worked fine until
I also have this same problem, I even fitted new lamp, did yuo get this solved
Posted on Mar 02, 2010
SOURCE: Malibu transformer 120w 1-8100-9120-01 transformer
I don't have repair for defect timer, except return to Home Depot and exchange for another.
Try unplugging timer to see if will reset. There is no specific reset button on timer.
Test outlet with circuit analyzer to confirm there are no electrical problems.
The label shows advisories: Don't use extension cord, unplug unit when working on bulbs, and plug unit into GFCI protected outlet to protect from surge and short.
Other advisories not shown: Unplug power pack if breaker trips or if power goes out. Wait until power is on before plugging back in. First bulb should be 10 feet from unit. Do not wrap extra cord around power pack. Match bulb wattage and power pack wattage: 200 watt power pack should have 200 watts and not more or less. Replace bulbs as soon as they burn out.
These advisories should not affect initial operation of timer, but are things that shorten life of power packs,
Open following links for resources:
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#dawn-dusk
Posted on Aug 28, 2011
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
I have just purchased 3 new Philips MR16 10w LED lamps to try in existing 12v 50w fittings - each with its own electronic dimmable 6o v/a elec t/x. As soon as the lights are switched on with the new lamps...
The LED light bulbs operate at 3 to 5 V usually. The noise your hearing is a result of the voltage reduction within the internal workings of the lamp base. The lamps should be installed with an
LED driver vs a transformer power supply.
This is usually on most packaging:
LED MR16 lamps operate in the same fittings as regular 12V lamps. However, they work best when they are mated with an led driver in place of the transformer.
Example of an LED driver:
http://www.google.com/products/catalog?hl=en&safe=off&rls=com.microsoft:en-ph&q=LED+Driver&um=1&ie=UTF-8&tbm=shop&cid=16162019396751156854&sa=X&ei=HzQpTqOWOK_NmAX0-LWqDA&ved=0CEcQ8wIwAg#
The noise will not go away unless you use an LED driver with the MR16 lamps.
Thanks for choosing FixYa.
Kelly
Jul 22, 2011 | Hardware & Accessories
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
1997 grand caravan trouble with signal lights
I found out it had a after market trailer hitch lighting, and it had its own little circut board, and the board was all burnt up. So all I did was cut the wires and took the wiring harness out and works like new...
Mar 27, 2009 | 1997 Dodge Grand Caravan
My new itouch will not boot up. It just seems to be dead
Check the wall outlet where the Power Transformer is plugged in and verify that it has current by using a lamp or something like that. If ok, then...
Check the laptop battery for charge state. The indicater light should show full or good charge. If not, the battery could be dead....
If no current from the adapter, the battery goes dead in 2-3 hours of use.
Daniel Bonnici
Mar 27, 2009 | Dell Inspiron 1525 Notebook
Lamp has been replaced but TV wont power up?
Feb 15, 2009 | Zenith E44W46LCD 44" Rear Projection...
Hi there
Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
Amp power
Make shure with an ohm meter that the primary and secondary windings have very little resistance on the main trasformer,then check voltage in trasformer and out from transformer...BIGRED
Sep 02, 2007 | Audio Players & Recorders
Crafts & Hobbies Logo
27 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
