Question about Fujitsu Heating & Cooling
Astg07cmca The timer button on the front panel of the air conditioner blinks 7 times with the economy indicator flashing with it. We have turned off at circuit breaker and reset remote then it works for 1hour - then it turns itself off and starts blinking again. continuously does this
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
bobotfel
  • 236 Answers
SOURCE: LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Posted on Feb 16, 2009
  • 288 Answers
SOURCE: HI, I have a Fujitsu ASTA18lCC. Fan working but
trying to get the compressor to operate. it could be a bad capacitor and the compressore wont start or maybe the compressor is burned up
Posted on Dec 15, 2009
Testimonial: "Thanks for the advice. It turned out that we had a blackout after the AC had started playing up. The blackout seems to have sorted out the problem.Thx"
icemelts
  • 246 Answers
SOURCE: air conditioner
There is a fuse inside the control panel of the AC itself. You have to take the cover off (from inside on the ceiling) and look up in there with a flashlight to find it. It is usually a very small amperage fuse - I think a 1 or maybe a 5 amp.
hope this helps
good luck
Posted on Jul 29, 2010
  • 5 Answers
SOURCE: My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
Posted on Aug 06, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
The unit is working but Operation and timer light flash 4 times then timer light flashing 3 times
It depends on the model as some models error codes differ slightly but this is the typical code for operation x 4, timer x 7:
VDD permanence stop protection (Electric air clean)
When the air cleanness monitor trial protection operates 4 times.
> Only clean air permanent stop.
[Diagnosis Point]
The front panel is closed.
The foreign body such as dust doesn't adhere
Aug 30, 2015 | Fujitsu Heating & Cooling
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Fujitsu halcyon economy light and operation light flashing
I have a fujitsu DC inverter model no. ASYG18LFCA not a week old as yet, when I turn it on it works fine for 5mins. then stops and after a short time the timer and economy lights start flashing, can anyone help on this, please.
Derrick
Apr 02, 2012 | Heating & Cooling
How do you reset the filter reminder warning light?
Filter Replacement
Filter Replacement Indicator:
Your Defender® is equipped with a Filter Replacement Indicator located on the front
panel. Anytime this red indicator flashes, it is recommended that you call your authorized
FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops
flashing and remains solidly illuminated, it is recommended that you change your filter. To
receive full benefit from your Defender® and to extend your warranty, it is strongly
recommended that you follow the filter replacement schedule suggested above. Under higher
pollution levels, your filters will need to be replaced more frequently.
The Filter Replacement Indicator is operated by filter time in use and is controlled by an
onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter
Replacement Indicator will begin to flash. It will continue to flash until the you reach 12
months of time in use, at which time the Filter Replacement Indicator will stop flashing
and remain solidly illuminated.
After replacement of your Medi-Filter® Cartridge, you must reset the Filter
Replacement Indicator's timer. When the timer has been properly reset, the Filter
Replacement Indicator will turn off.
Resetting the Filter Replacement Indicator Timer:
After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the
Filter Replacement Indicator's timer can be reset by performing the following sequence of
steps:
1 Plug unit into outlet.
2 Press power On/Off switch to the On ("I") position.
3 Allow unit to start running at low speed.
4 PRESS and HOLD both the Up and Down arrow buttons until the Filter
Replacement Indicator starts to blink.
5 Release both the Up and Down arrow buttons.
6 While the Filter Replacement Indicator is still flashing*, again PRESS and
HOLD both the Up and Down arrow buttons until the Filter Replacement
Indicator turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will
turn off and not flash again for 11 months. If the Filter Replacement Indicator remains
on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when
the buttons are pressed the second time. The Filter Replacement Indicator will continue
to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Note: Under higher pollution levels, your filters will need to be replaced more frequently.
Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call
1-440-846-7800 for the Distributor nearest you.
http://www.filterqueen.com/pdf/defender.pdf
Mar 02, 2011 | Filter Queen Defender Air Purifier
My air conditioning unit will not turn on... the model is AR-SY1 and flashes with a red light on the timer button?
The lights on the front panel will flash in a certain order depending on the fault. Please count the number of flashes & let us know.
Aug 13, 2010 | Fujitsu 24R1 Air Conditioner
Fujitsu ASU9RLQ
check indoor unit sirkit board
Mar 10, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
