Question about Electronics - Others
Cp14ln battery dead - Electronics - Others
MY BATTERY DIES AND MY REMOTE START WONT WORK. I TRIED THE TRUNK AND LOCK BUTTON AND CHECKED THE SWITCH AND IT STILL WONT START.... HELP PLEASE ITS COLD OUT SIDE
Use a proper key to open the door, pop the hood and put the battery on to charge.
Remote starters are notorious for causing problems.
Jan 05, 2016 | Cars & Trucks
2007 jeep gc won't start. Lights, battery all Dash lights had been acting strangely before this happened. Turned the car off, Swapped AC relay with starter relay and nothing.
i guess you mean starter is dead, and all lights dead.
pointing to....
the battery is dead, did you jumper cable start it?
if that works the battery is bad, dead or only dischanged.
if that dont work make sure the battery cable lugs are cleaned.
no rust on cable ends( that green junk there that all cars get)
if the head lamps die (they work key off so...)
then the battery is dead, or rusty lugs.
if battery is dead, charge it. using a charger.
Nov 08, 2015 | Jeep Cars & Trucks
When stalled car will not start again for some time and battery seems dead. What is this?
that is because it is dead?
that key dead thing is called NO CRANK, not no start.
no car starts unless cranked, or push started or gravity started,
so its a NO Crank issue,
and the stalls, well if the battery drops below 10v the EFI system
stop working just like your lap top does, or CEL phone
and for same reasons.
most folks do a jumper cable crank next. like the AAA tow truck man does first, and for good reasons.
this proves what is wrong,
1: battery was dead (car cranks now)
2: starter dead. or key line dead, if not. cranking now.
my guess is its #1
if battery was dead, then it is
  • bad battery.
  • only discharged, so why not charge it?
  • or phantom drains, (over night parking battery dies)
  • or alternator is dead, (chargelight glowing? test alt.
Mar 03, 2015 | Suzuki Swift Cars & Trucks
The battery is almost bead, the car won't start, how do I jump start my touareg 2006 V6
place the positive lead from the jump battery to the positive terminal of the dead battery. take the negative lead from the jump battery and place it on the engine or other metal point--- NOT TO THE NEGATIVE TERMINAL OF THE BATTERY-- If you do then you run a real risk of a power surge that will fry the ECM
However with a dead battery if the cells are failed then the power from the jump battery will probably feed the dead short in the dead battery and it may not work
Best have a load test done on the dead battery to see if it is faulty (cold weather) or just flat
Jan 13, 2015 | 2006 Volkswagen Touareg
Can a dead battery be recharged and how
If you have a capable battery charger, then a dead battery can be recharged. I would suggest recharging the battery to the proper voltage and then letting it set for 24 hours. In 24 hours check the battery for the correct voltage. If it maintains the charge, then you should be okay to reinstall the battery. If it does not, then you may have a dead cell in the battery and it would need to be replaced. Video about How to Test Battery
Aug 28, 2014 | Exercise & Fitness
Battery dead open boot
its should still open even with the battery dead all doors should open manually with the battery dead
Aug 03, 2013 | Mercedes-Benz Cars & Trucks
My fone dead put charger in does nothing dead dead dead
Nokia phones are notorious for slow response time when recharging from a completely dead battery.
Remove battery.
Make sure there is good contact between all of the contact points.
Replace battery.
plug in charger.
wait for at least 5 min.
If recharge symbol does not appear in window, then one of these things has occurred:
1. Phone has internal damage or water damage. no way to fix without nokia service.
2. Battery is dead. Try a new battery
3. Charger is bad. Try a new/different car charger or home charger.
These chargers are very inexpensive on Craigs List, try to solve it before throwing away the phone. Good luck,
A former Nokia employee.
Feb 16, 2011 | Nokia Cell Phones
Battery seems to be dead jump staring didn't help 2005 jetta
Battery can be so dead that it won't take a jump. If it is the original 5 year old battery, you would be well advised to scrap the battery. If it is newer than 5 years old, charge battery on a battery charger for enough time to properly charge it. Then test it. Still dead? Scrap battery.
That's all I can offer you as you don't say why you think you have a dead battery.
Aug 02, 2010 | Volkswagen Jetta Cars & Trucks
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
Nov 15, 2009 | CyberPower Computers & Internet
Dead battery for one unit won't charge at all. voltage -0- both radios and charger work fine. where can I get battery? P/N MN-160001 capacity 950mAh
First put the dead laptop battery in a zip lock.
Then put the zip into refrigeratory and keep it in freezer for 14 - 15 hours.
Afer waitinf for a long time, take the dead laptop battery out of refrigeratory .
Using clean and soft cloth to dry the battery and get the battery to room temperature (about 20° - 25°)
In the end fully charging and discharging the battery for 3 - 4 cycles.
Now you would see that your dead battery holding up charge for 1-2 hours.
See the detail video in metacafe.com
View more info in : http://www.laptops-battery.co.uk/blog/revive-dead-laptop-battery.htm
Sep 13, 2007 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Open Questions:
Electronics - Others Logo
76 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
