Question about Garden
I have a 33cc makita chainsaw and the oil is not coming out but the reservoir is filled but it's not going on the chain how do I fix
    New Friend:
  • 7 Answers
I am not familiar with he makita brand but as most saws are all very similar it shouldnt be much of a problem. chances are it is just a bit of saw dust in the line needing a air compressor blow out or it is not picking up the oil. the later i dont know how to do and as there are lots of small parts in a oiler i strongly suggest you get the help of someone that knows what they are doing to help you. Is it under warranty at all take it back as its a warranty issue. i have had the same issue with my stihls and needed a new oiler at $100 fitted so not cheap
Posted on Apr 16, 2014
nomad man
SOURCE: mcculloch chainsaw not oiling the bar and chain.
check the hole that goes to the bar and the hole coming out of the chain saw to see that it is not plugged
Posted on Jun 12, 2009
  • 154 Answers
SOURCE: Ryobi 18 Volt Cordless Chainsaw needs chain oil?...
you can use a reg bar oil or a lightweight motor oil
Posted on Aug 11, 2009
dontbother10
  • 2220 Answers
SOURCE: CHAIN SAW QUITS CUTTING AS IT HITS WOOD.
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
HTH
Lou
Posted on Sep 09, 2009
dontbother10
  • 2220 Answers
SOURCE: makita 520 chainsaw chain carnt get the right chain
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
An Oregon part Number can easily be converted to other manufacturer's. HTH
Lou
Posted on Oct 02, 2009
duane_wong
  • 6826 Answers
SOURCE: Can i get instructions to download on how to
Got to homelite.com and input your model number.
WARNING:
When servicing, use only identical Homelite
replacement parts. Use of any other parts may
create a hazard or cause product damage.
WARNING:
Always wear safety goggles or safety glasses
with side shields during power tool operation or
when blowing dust. If operation is dusty, also
wear a dust mask.
GENERAL MAINTENANCE
Avoid using solvents when cleaning plastic parts.
Most plastics are susceptible to damage from
various types of commercial solvents and may be
damaged by their use. Use clean cloths to remove
dirt, dust, lubricant, grease, etc.
WARNING:
Do not at any time let brake fluids, gasoline,
petroleum-based products, penetrating
oils, etc., come in contact with
plastic parts. Chemicals can damage, weaken or
destroy plastic which may result in serious
personal injury.
LUBRICATION
All of the bearings in this product are lubricated with
a sufficient amount of high grade lubricant for the
life of the unit under normal operating conditions.
Therefore, no further lubrication is required.
REPLACING THE guide BAR AND
CHAIN
See Figures 34 - 43.
DANGER:
Never start the engine before installing the
guide bar, chain, clutch cover, and clutch drum.
Without all these parts in place, the clutch can
fly off or explode, exposing the user to possible
serious injury.
maintenance
Fig. 34
Fig. 35
Fig. 36
WARNING:
To avoid serious personal injury, read and
understand all the safety instructions in this
section.
n Always place the switch in the stop “ ” position
before you work on the saw.
clutch
cover
Run
Position
sprocket
Page 26 — English
cutters
bar
groove
chain drive links
Fig. 38
maintenance
chain rotation
chain drive links
Fig. 37
n Make sure the chain brake is not set by pulling
the chain brake lever/hand guard towards the
front handle to the run position.
NOTE: When replacing the guide bar and chain,
always use the specified bar and chain listed in
the Bar and Chain Combinations section later
in this manual.
n Wear gloves when handling the chain and bar.
These components are sharp and may contain
burrs.
n Press in on the clutch cover lock knob and rotate
counterclockwise until the clutch cover can be
removed.
n Remove the bar and chain from the mounting
surface.
n Remove the old chain from the bar.
n Lay out the new saw chain in a loop and
straighten any kinks. The cutters should face
in the direction of chain rotation. If they face
backwards, turn the loop over.
n Place the chain drive links into the bar groove
as shown.
n Position the chain so there is a loop at the back
of the bar.
n Hold the chain in position on the bar and place
the loop around the sprocket.
n Fit the bar flush against the mounting surface
so that the bar studs are in the long slot of the
bar.
n Replace the clutch cover ensuring that the
adjusting pin in the clutch cover is in the bar
chain tensioning pin hole and that both bar
studs are securely in their respective holes in
the clutch cover.
NOTE: The adjusting pin may need to be slightly
repositioned with the chain tensioning dial so
that it is aligned with the position of the bar chain
tensioning pin hole.
n Replace the clutch cover and rotate clutch
cover lock knob just enough to hold the cover
in position.
NOTE: The bar must be free to move for chain
tension adjustment.
n Lift the tip of the guide bar up to check for sag.
n Remove all slack from the chain by rotating the
chain tensioning dial clockwise until the chain
seats snugly against the bar with the drive links
in the bar groove.
n Release the tip of the guide bar and, if the chain
sags, turn the chain tensioning dial clockwise.
Repeat this process until sag does not exist.
n Hold the tip of the guide bar up and tighten the
clutch cover lock knob securely.
Posted on Jul 08, 2010
How much chain oil do I need for my poulan chain saw?
fill the oil reservoir to the top, each time you fill gas reservoir, a quart of oil usually should last you the use of a gallon of gas.
Jun 04, 2014 | Poulan Pro Chain Saw 46cc 20"
Chain keeps coming off my new 16" Makita chainsaw. Any suggestions?
Make sure that your chain is properly tightened and that the bar does not have any dents or dings in guide groove.I like to have my chains tightened to where you can pull them up at the mid-point of the bar about enough to fit the thickness of a nickle in between it and the bar.Do this when saw and chain are at operating temperature.If nothing else helps try a new chain if you have reached the end of tensioning adjustments. Thank you.
Mar 25, 2011 | Makita 33cc Chain Saw w/16" Bar DCS34-16A
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
What should the compression be for the makita dcs34?
As far as i am aware it sould be between 60 - 80 PSI, 40 - 60 psi indicates ware any lower than 40 no hope
Sep 07, 2010 | Makita DCS34 Commercial Grade 14Inch 33cc...
Want to fine gas and oil mixture ratio for Homelite 16 inch 33cc
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Homelite ZR10926 16 Chain Saw
Chain is coming loose quite often is there a way to prevent that?
If you are already holding the nose up when tightening please post back below. Is it oiling? There are probably burrs (should be removed) the following helps with repair and installation.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 10, 2010 | Makita 33cc 14-Inch Bar 1.9 HP Gas Powered...
Oil leaking out of electric remington saws(pole and regular)
if you jump on the net ,google remington electric chainsaws you will have the info up front---------personaly I think they should have stuck to shavers
Aug 25, 2009 | Remington Electric Chain Saw
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
