Question about Whirlpool Inglis IP4400 Washer
Inglis front load IFW7200TW motor hums
Panel lights up but motor only hums. No motion. Unable to drain
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: IFW7200TW Inglis front load washer stopped
The washer you have is a "direct drive" system. The motor runs both the pump and the agitator on the washer. If you get something hung up in the pump, it will not allow the washer to agitate, spin, or pump the water out. Here is a video to show you how to get to the pump.
Posted on Jan 03, 2011
Why doesn't it fill or run?
motors don't hum unless there is a faulty start /run capacitor in the circuit
the hum can be from a faulty water control solenoid
could be a faulty program control board
call in a technician and get a quote
Feb 15, 2016 | Summit Professional SPW1102 11 lbs. Front...
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
Sep 13, 2014 | LG WM2455HG XL Front Load Stackable...
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
LG front load washer does not drain after cycle. Motor runs,drum moves forward and reverse but seems pump doesn't pump. Drain hose clear as well as filter area.
Check for 120 volts to the pump motor while in drain mode, if the pump does not run, or just hums, replace the pump motor. Some LG's have both a recirculating and drain motor on the pump casing, so be sure to replace the correct motor.
Dec 30, 2009 | LG WM-2277HW Front Load Washer
Machine not draining
the washing machine uses an electric pump. Unlike the older machines pumps that used to be driven by a belt, Then newer washers pumps are driven with an electric motor.The first thing you need to do is to disconnect the washer from the wall outlet
Next you need to remove the front panel from the washer. To do that you will need to be use a spatula. You need to place the spatula between the front and top panels to compress the two front panel holding clips.
After removing the front panel you need to connect the washer to the wall outlet.
Set the timer on the spin cycle and pull the knob to turn the washer on. Listen to see if you could hear the motor on the pump turning or humming. since the motor hums, that is an indication that something is preventing the pump motor from starting.
Disconnect the washer from the wall outlet, empty the water from the machine (make sure you have plenty of towels to clean any water spills) this connect the hoses from the pump and check the pump for any obstructions.
If the motor on the pump is not running at all, then you'll have to check the pump motor for continuity. If the pump motor checks OK for continuity then you need to check the two wires that connect to the pump to make sure that the timer is sending 120 volts to the pump.
In conclusion, is not that hard to find out why your front load washer is not draining. You either have an obstruction, a bad pump or a bad timer.
To check the motor in the electric pump you will need to get the multitester. analog multitester. Make sure you read the instructions on how to use you multitester to read resistance and voltage
Mar 14, 2009 | Tricity Bendix AW1000W Front Load Washer
Please help!
remove bottom panel remove as much water as possible from tub ..have lots of towels handy remove clean out port on pump clean and reinstall...also ck as far into pump for something jammed in impeller ..pump may need to be removed to clean if unable to clear jam ..3 screws hold pump motor to pump body remove if necessary also ck to see if pump impeller is spinning freely on motor shaft should be some resistance when turning if impeller spins freely replace pump
Oct 04, 2008 | Kenmore Elite 45986 Front Load Washer
Samsung Silvercare hums, but does not run
FIXED!!!! amen. Attached to the back of the washer was a plastic bag with a tech spec pamphlet. Inside the pamphlet were instructions for running tests via the front control panel on the various cycles to weed out the problem -- fill, spin, drain, etc. The test failed on the draining section citing a problem with the drain pump. So long story short and MANY towels later, I found a small finishing nail in the motor. I had removed the hoses thinking there might be a blockage, but found nothing. So I removed the motor and washed it out. Nothing odd there. So I took the front off the motor and found the nail. It somehow made it through the drain holes in the washer drum but got stuck in the motor.  Thank you Samsung for taping the tech manual to the back of the washer. I could not find it anywhere on the web for this model. After discovering the testing available via the contol panel and the simplicity of the machine, I love Samsung.
Apr 01, 2008 | Washing Machines
Won't Run
The humming usually means the motor is trying to start but can't either because of weak windings or not enough electrical power. Need to check the motor control.
Mar 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Inglis IP4400 Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
