Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Finalizing disc for magnavox ZV427MG9
AFTER DISC RECORDS HOW DO YOU FINALIZE DISC?
ThaMp3Doctor
  • 8596 Answers
SOURCE: Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
SOURCE: Can't figure out how to finalize, I record fine
Insert the dvd you want to finalize. When the menu loads press Stop and then press Setup on your remote control. Scroll down to disc edit and press the Enter or OK button. You should see the word Finalize there, select it and then it will ask to Finalize Yes or No. Select Yes and it should finalize your disc perfectly and play on any player.
Posted on Mar 13, 2009
SOURCE: Philips Magnavox MWR10D6 DVD Recorder Finalize dvd
hit stop go to setup menu pops up scroll down to finalize and hit enter
Posted on Aug 02, 2009
SOURCE: cant finalize dvd on a magnavox zc320mw8
you have to push stop from the title menu, then push setup. Then go to disc edit and finalize is there
Posted on Nov 24, 2009
SOURCE: hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Posted on Dec 29, 2009
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Can't view recorded DVD
if the movie you recorded ? was copy protected. then your dvd prob did not record
Nov 22, 2012 | Magnavox ZV427MG9 DVD Recorder/ VCR
How do you finalize a dvd ?
push play - stop - go to set up, disc edit, go down to Finalize...
Feb 29, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Don,t have a manual
NEED TO KNOW HOW TO FINALIZE DISC ONCE RECORDED
Jun 14, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
Finalize DVD
I have a dvd recorder with vcr it is a model # zv427mg9 we have lost our manual and do not know how to finalize the disc. We have transferred video from vcr to dvd and can't figure out how to finalize, please help?
Dec 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Sep 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
14 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
