Question about Canon PowerShot G10 Digital Camera
When switching camera on there is a blank screen
Is the caused by dirt in camera, needing a new battery. Also when it finally comes after taking a picture it is just a blank picture.
  • 4 Answers
In settings, you might have switched off the image for when the camera starts. Turn it back on. Also, if that doesn't work, try deleting some photos or change the sim card or the battery itself, not charge it.
Posted on Oct 21, 2014
advance
  • 107 Answers
SOURCE: Blank LCD screen
Thanks for that link, I will keep it handy! Be careful however, because the exact same symptom can be caused by a stuck shutter. To tell if it is a stuck shutter follow these steps: 1. Turn off the flash!! 2. Look down into the lens. 3. Take a picture. Did you see anything change? The opening at the center should be momentarily covered by a matte black shield. If you take a picture and see no change inside the lens then the shutter is stuck closed or open. If Canon finds your shutter to be stuck and not a CCD failure, the repair will not be free.. very not free. David Millier Advance Camera Repair
Posted on Mar 13, 2007
advance
  • 107 Answers
SOURCE: canon powershot SD 100 - I can't see anything but a black screen
This problem is caused by a stuck shutter assembly. Normally the shutter is open which allows light to enter the image sensor and show you the live preview you see on the screen. When you take a picture the shutter closes which allows the image sensor to record what was seen at the exact moment the shutter closed. The shutter is stuck closed, causing the image sensor to always be in the dark. These shutter assemblies are extremely small and delicate. The miniature parts can become jammed with just the slightest bit of oil or contaminant, or the slightest misalignment of components. The problem can sometimes be fixed by gentle tapping of the camera on a solid surface. If you are going to try this be VERY careful, and do not tap the camera on the buttons, lens, or battery door. If this does not solve your problem then the camera is going to have to be taken apart and the shutter cleaned and reset to allow free movement. This repair costs $125 to $145.
Posted on Jun 16, 2007
t00nz
  • 4738 Answers
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Posted on Mar 15, 2008
SOURCE: canon powershot s21s problem
i AM HAVING THE SAME PROBLEM.
Posted on Jun 16, 2008
SOURCE: Problems with LCD screen
I called Canon support and they told me to hold the Menu button down for about 6 seconds and then it will ask you if you want to reset, check okay and then use the set button.  If that doesn't work they will repair your camera for free... it's something to do with the CCD unit.
Call Canon support 1-800-828-4040
Posted on Jul 03, 2008
I have a Panasonic DMC-FX12 digital camera. Before I left on vacation, I took all the pictures OFF of the camera and recharged the battery. I took only 4 pictures before the error message "Built in...
You copied all your pictures, but they still exist on the memory card. You need to go into the menu and erase the pictures. As far as the lens not coming out, there may be some dirt in the mechanism.
Oct 20, 2010 | Cameras
Blank screen
If you can play back captured images without any problem then your camera has a faulty CCD sensor. If you can get hold of a new CCD sensor block for this model somehow then you can install it yourself. Otherwise camera has to go to your Nikon agent.
Sep 14, 2007 | Nikon COOLPIX P4 Digital Camera
Camera - Fujifilm Finepix A500. The screen goes blank when taking a picture. It does not take the picture and although the screen goes blank and only comes on again when the power button is pushed the lens...
What worked for me with the same problem is to reformat your internal memory and/or picture card. First, download all your pictures saved from your camera to your computer, since the reformat will wipe them off the camera memory. Next, follow the instructions on page 75 of your manual. If you don't have it anymore, you can download it:
http://www.fujifilmusa.com/shared/bin/FXA400_A500_Manual.pdf
Hope this works for you.
Jun 13, 2010 | Fuji FinePix A500 Digital Camera
I have Canon EOS 300D digital Rebel. I have had intermittent problem with the camera display screen going blank even though I put a freshly charged battery in. Usually I can take a couple pictures then the...
Strange, intermittent problems with the EOS Digital Rebels can be caused by a defective shutter release switch. We charge about $85 to replace it.
Nov 12, 2008 | Canon Cameras
Blank screen
Change the aa batteries
Which other one are you refering to?
When you have changed the batteries and tried and sill in trouble come back
Make sure you change to the correct type of battery -refer to the manual
Sep 02, 2008 | Canon PowerShot A300 Digital Camera
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
Finalizing dvd
I had the same problem for about an hour. I finally got it, though not sure how. I think it had something to do with the green button on the on/off switch. I pressed it down while at the same time pushing the on/off button down to "mode". When I went back to finalize it yet again, I got the option to select "Yes". Hooray!
Dec 24, 2007 | Panasonic VDR-D100 DVD Camcorder
No image
79da3bf.jpgWhile in picture taking mode, press that button. It will restore your viewer.
Nov 20, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Psp turns on but there is a blank screen
it probably froze try and remove battery. if that dont work turn it on and wait a second then hold the power switch in the off position but do not let go until it turns off that should completey restart it.
Jul 14, 2007 | Sony PlayStation Portable (PSP) Console
Canon PowerShot G10 Digital Camera Logo
63 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
