Question about Dell Inspiron Mini 10v Netbook Computer
I had the poor status with the old battery in my laptop now i replaced it with the new one and I fully charged it but the battery health status is still poor
Battery health status poor
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 94 Answers
You can try to save battery time by changing your laptop to work in balanced mode, or just adjust the screen brightness lower. Screen takes a lot of power.
Posted on Jun 04, 2014
4 Suggested Answers
  • 3940 Answers
SOURCE: E1505 Primary battery not install
There appears to be a problem with the charger curcuit of the motherboard. Flash the BIOS to the latest version, if no change, replace the motherboard since you've already replaced the battery.
Posted on Mar 16, 2009
bunnydawg
  • 5158 Answers
SOURCE: Dell C610 Charging LED status
battery light should be green (or blue)
Posted on Sep 15, 2009
  • 2567 Answers
SOURCE: I just replaced my laptop battery. The new one was
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 06, 2010
Testimonial: "thank you i will try the dry brush, and battery variation. The amperage matches up fine. If these dont work i ill take it in for service gracias "
I keep losing charge on my battery I have a sony xperia
  • Install "Repair Battery Life PRO" from Google Store, start the application, tap on Start, review the Health status of your battery.
  • If battery health status is "Good", there is a battery drain from an application behaving bad. Best method includes backup-ing your photos, contacts and other important things to your external memory SD-Card. You can use "Super Backup & Restore" from Google Store for that purpose. After backup, pullout your SD-Card and revert your phone to factory setting. After restart reinstall "Super Backup & Restore" and restore everything from it. After installing apps that you have been used, you will see the program that misbehaves.
  • If battery health status is not stated as "Good", replace battery with a new one
Nov 22, 2016 | Sony Cell Phones
Laptop battery plugged in,not charging
Try draining the battery completely and then charge it fully with the laptop switched off.
If you don't know how to drain it out completely, please let me know.
Jul 02, 2017 | Toshiba Satellite X205-S9359 Notebook
When i boot up, my Compaq CQ20 displays the message that the battery has low storage capacity. Battery time is now down to 15 to 20 minutes at full charge.
If you laptop is more than two years old then it is possible that the battery is faulty as many of the compaq laptops have poor back up battery orr quality retained.
Check the adapter on the PC , check if the adapter charges the battery to full capcity , now if this charge wont lat more than 20 minutes , you might need a new one.
Discharge the battery fully and charge few times as the last resort.
Feb 23, 2011 | Compaq Computers & Internet
Hiiiiiiiii......my hp dv6-2165tx battery does not charge properly.......when i plugged in it shows charging but after some time it shows not charging &plugged in.........why
You may need to diagnose the status of your battery.
Press control+Shift+Delete to do so. Make sure it is plugged in.
If it reports the health is good, then it is the heat sink responsible for the problem. Get your laptop serviced at the service centre.
If it says primary battery not detected and health 'Replace', your battery may be old enough to be replaced.
If the battery backup has reduced drastically within past few days, then you need to get the battery replaced.
your battery may be covered in your HP warranty.
One thing you need to know is that, plugged in & not charging is a safety step taken by HP to ensure that your computer doesn't get overheated. So, you don't need to worry much unless it is persistant.
Again, kindly use your laptop while keeping it on a hard surface so that the processor fan & exhaust doesn't get blocked.
Reagards.
Jun 30, 2010 | Computers & Internet
Power light blink orange 4 times, 1 green?
My guess is that the battery is worn-out -- no longer accepting a charge, nor holding a charge. Replace the battery, or find a specialty business that "refurbishes" batteries (by opening the case, replacing the cells, and re-sealing the case).
Mar 04, 2010 | Dell Inspiron 6400 Notebook
Power problems Inspirion 8600-battery not charging
Most Dell batteries have an LED indicator that allows users to see how much run time and how much overall battery life are available at the touch of a button.
To check battery charge, press the button and the number of lights that appear will tell you charge status. If all lights appear, you have a fully charged battery. Each light that appears accounts for approximately 20% charge.
To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition and approximately more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear, approximately less than 60 percent of the charge capacity remains, and you should consider replacing the battery
if the ac adapter will power the laptop without the battery installed its fine. if the cord is fine and your battery is fine its a mother board issue and it will most likely have to be replaced
Feb 05, 2009 | Dell Computers & Internet
Blinking battery light
Green is charged, Orange is Charging and Red indicates a low charge or a possible weak or defective battery. All modern batteries are controlled by a microprocessor that monitors the health of the cells. Even if the battery is holding a workable charge, it can still be deemed "bad"
If the battery is fairly new you might get a replacement from Dell, if its a year or more old, it could be dying an early but not abnormal death. If more than 1.5 years old, be sure to check the Dell battery recall list as some of these are recalled and you'll get a free battery replacement if its on the list!
-Good luck
Jan 05, 2009 | Dell Inspiron 9300 Notebook
Acer Aspire 5580 poor battery
Its time for a new battery. After a period of time of using a battery, the amount of charge it can hold depletes. Even if you always have it plugged in. Usually, batteries only last 18-24 months which is sad, seeing how much they cost. I'm a computer tech and see this problem everyday first hand. The best thing you can do is buy a battery from eBay and save yourself a bunch of money. Local retail stores charge up to 3 times as much for a battery. Good luck and I hope this helps..... :>)
May 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell Inspiron Mini 10v Netbook Computer Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
