Question about Nikon COOLPIX S3500 Digital Camera Purple
Menu button doesn't work - Nikon COOLPIX S3500 Digital Camera Purple
My menu button doesn't work
Your remote control need cleaning.
Dec 23, 2012 | Universal MX-900 Remote Control
Menu button doesn't work on kodak easyshare dx4530
Perform a power resetting and check the operation.
Jun 23, 2012 | Kodak EasyShare DX4530 Digital Camera
I got a NES (finally) but i got a problem. when i start it up with (for example) zelda i can select a save, in other words when I push the up or the down button it does nothing. But when i press start to...
The reason it doesn't work in the menu is because it doesn't use the D-pad (the plus-shaped button that you use to move around). To go through the menu options, you need to press the Select button (that's the left of the two small buttons in the center of the controller). Many games use that to select menu options instead of the D-pad.
Jul 06, 2011 | Nintendo NES Console
Cannot access the menu
there should be a button labeled MENU on the side of the TV or try the menu button on the remote. If that doesn't work try unplugging the tv and re-plugging it and repeat.
May 20, 2011 | Televison & Video
OSD LOCKOUT Display on my Screen HP L1940 Silver Lcd
Release the menu button (check if anything is leaning on it), and press and hold the menu button again until the message disappears (app. 10 seconds). If this doesn´t work, the button may be stuck, or there´s a problem with the hardware.
Nov 02, 2010 | HP L1940 19" LCD Monitor
When i try to adjust the monitor controls message comes up OSD locked, how do I unlock it
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Oct 24, 2010 | Computers & Internet
Just connected a HF 225 monitor to Vista Home 32 bit. No real manual; install CD does nothing. When I press the Menu or Brightness buttons on the monitor I get no response to keyboard or mouse clicks to...
They only include the Win7 driver on the CD. I'm surprised it doesn't work with Vista. Did you try going into the HF225_win7 directory and clicking on infinstallWIN7?
The monitor menu doesn't work with the keyboard. You have to press a combination of the three buttons to the left of the on-off button. It's not very intuitive.
Aug 08, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
OSD lock flashing on monitor
To remove the OSD lock, kindly use the steps as shown in the attached image:
Hope this solves your problem. Thanks for using FixYa.
Jun 14, 2010 | ViewSonic E70f (White) 17 in.CRT...
My 30 gb
Hold down the center and menu buttons at the same time. If that doesn ot work...switch the hold over to hold and back off and try holding the center and menu buttons down again.
Apr 16, 2008 | Apple iPod MA446LL/A MP3 Player
Nikon COOLPIX S3500 Digital Camera Purple Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
