Copiadora canon C-5030
Codigo error ---E-000075-0103 como lo resuelvo, cada vez que trato de imprimir siempre aparece este codigo
idriss47
  • 26 Answers
SOURCE: error EOOO ir 2000
Hello ...
E000 The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)
Posted on Jan 09, 2009
SOURCE: Oxd0620230 reset power
my printer is a hp officejet j5750 all in one, the probem is that I can't scan in it, but I can print, send fax, an make copy in it, so the only problem is the scaner, plese help me
thanks.
Posted on Mar 04, 2009
System error E000
Posted on Aug 03, 2009
pineworks
  • 4041 Answers
SOURCE: error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Posted on Jan 25, 2010
SOURCE: Error de sistema
tengo una fotocopiadora canon 1670 y me dice error del sistema e000 nesecito saber que sera por favor
Posted on Jun 03, 2010
Alcasas aver esto?
"Magallanes": cinco razones para ir a ver la pel?cula ' Cine ...
elcomercio.pe/.../magallanes-cinco-razone...
Translate this page
El ComercioAug 21, 2015 - Dami?n Alc?zar es el protagonista, con todo lo que eso implica: su ... Como dijo el director, es tal vez el cine un espacio donde esto pueda ...
Nunca pens? poder llegar a ver esto.... - Dimueble ...
https://www.facebook.com/.../10152594632655199
Translate this page
Nunca pens? poder llegar a ver esto. Lix, el l?piz con el que ... Itzcoatl Alcazar Edgar Tellez · August 8, 2014 at 7: ... Remove. Itzcoatl Alcazar Sandra Morales.
Baltasar del Alc?zar.
www.lcc.uma.es/~perez/sonetos/alcazar.html
Translate this page
Amor, no es para m? ya tu ejercicio,; Cansado estoy de haber sin Ti vivido,; Cercada est? mi alma de contrarios;; Di, rapaz mentiroso, ¿es esto cuanto ...
Luis Alc?zar puso a vibrar a todos con "Laura no est? ...
? 2:13
https://www.youtube.com/watch?v=CEn4IfJQw1A
Sep 28, 2015 - Uploaded by La Voz Per? Latina
Cada vez que vengo a ver otras nuevas audicione, siempre termino aqui en ... de aliento no saben cuan ...
Dec 25, 2015 | Cars & Trucks
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Hola. el prblema que tenia al principio con este
CERTIFICADO DE EXPERTOS AQUI TV, siga esta información que he proporcionado tres soluciones de largo a este tema / s
Solución 1
Antes de empezar a desmontar cosas, le permite probar su simple rutina retire el enchufe de alimentación y sistema de poder una copia de seguridad. También, por favor, intente su unidad en una canales diferentes para ver si el problema persiste en cada canal. Su principal del Consejo, Power Board, T-Consejo Regulador se sospecha que los problemas en este momento. Pulse y mantenga pulsado el botón de encendido durante unos 15 segundos, la unidad debe apagar por sí mismo después de haberlo encendido. Si no es así, entonces no te preocupes. Quiero saber si el problema persiste. El primer enlace a continuación le llevará directamente a la guía de solución de problemas si tiene que seguir adelante con el mismo error.http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Información adicional No se pudo TV y Monitores: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plaguepartes: www.shopjimmy.com
Le permite centrarse en la parte externa de la primera serie de televisión (95 por ciento de todos los problemas de la televisión están relacionados con cosas externas a la propia televisión) Compruebe la conexión física de todos los cables mediante la eliminación de cada cable pelado o RCA y volver a instalarlo (Cada cable de potenciaasí), una vez que haya quitado un cable, compruebe que no se deshilache, y si ya está desnudo, de empalme de una conexión nueva y fresca para ello. 5. Asegúrese de que NO hay otras radios uneeded, el sistema de las cercanías.estos sistemas, cuando se enciende, hará que la interferencia electromagnética y evitar que más que grave la interferencia de televisión SURGE PROTECTOR protectores contra sobretensiones representan más del 75 por ciento de las fallas eléctricas a los equipos de estéreo. Vamos a empezar con su toma de CA de pared. Es norma en América que 220 voltios de fuera de estos puntos de venta. Esto implica que cada dispositivo va a utilizar 220 voltios (dentro de esa zona de la red). En todo caso incluye un reloj de alarma está conectado a cualquier enchufe de salida de CA en las proximidades del equipo estéreo / TV, causará interrupción eléctrica, electrónica e impedir incluso de encender! El televisor necesidades dedicada energía eléctrica.Si el televisor se encuentra en la sala a continuación, desconecte todo lo demás en la sala de estar. Permite conectar el televisor a una toma de Dedicado. Revise todos los interruptores de luz para asegurarse que el poder es para el que toma. Compruebe el cable de TV para Desfibracion tanto en el extremo de la pared de CA y donde se conecta a la televisión.Compruebe todos los puntos de GFCI para garantizar que todos los botones rojo de reposición se empujan, compruebe los interruptores automáticos para la conexión adecuada y que están encendidos. Ahora, vamos a tratar el televisor sin que relacionada con cualquier servicio de cable, vídeo, dvd, equipo de música, etc Por favor, responda si hemos encontrado una solución.
Cuando la reparación de estas unidades, hay siempre varias variables a considerar. Primera visita para ver lo que ocurrió por última vez con la unidad, como hicieron los hijos juegan con videojuegos, ¿la electricidad salir debido al mal tiempo. Usted puede ver que hay muchas posibilidades, pero vamos a concentrarnos en lo que se produjo el pasado a la unidad. Una vez que determinemos lo ocurrido el pasado, podemos identificar la causa real del problema. La causa real puede estar asociada con problemas de proyección, las versiones anteriores (tubo de imagen), la interferencia de los dispositivos en las cercanías, e incluso una radio encendida y situada muy cerca de su unidad. Esto es normalmente conocido como interferencia electromagnética a la electrónica y es muy común el error que usted ha proporcionado hoy. Por favor, seguir buscando algo externo a la unidad antes de ver los componentes internos. He estado trabajando en estas mucho tiempo así que siéntete libre de seguir conmigo.
Jan 24, 2011 | LG Studioworks 552V 15" CRT Monitor
Cuando prendo mi optiplex 170 l me manda un error como de un cable pero no lo alcanzo a leer pork se resetea
A: Error DRIVER_POWER_STATE_FAILURE
todos mis drivers est?n actualizados o eso es lo que me aparece al ver cada uno de ellos.
Dec 22, 2010 | Dell OptiPlex 170L PC Desktop
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
Como configuro la copiadora impresora canon ir 1023
tiene que ser una 1023 con habilidad para imprimir. aunque no lo creas no todas las 1023 imprimen. si la tuya si imprime no debes tener mayor problema al conectarla via usb debe detectarla windows y se instala como una impresora cualquiera. ojo, el hecho que tenga puerto usb no quiere decir que sea impresora.
Sep 10, 2008 | Office Equipment & Supplies
Stereo
esta inabilitado porque cambie la beteria yen momento no tenia el codigo y aparedia en pantalla la palabea safe ,despues lo lleve al conseccionario para que me dieran el codigo el cual me dieron pero como todo aqui en este pais es un caos no pedieron por los momentos desabilitarlo ya que supuetamente tenian mucho trabajo en otras areas mas importantes que ocuparce del estereo en ese momento asi que tengo que pedir cita otra vez para cuando les venga en gana ,asi estamos en este pais sorri lo sieeto de veras tener que plantearlo de esta manera pero tengo que ver si lo puedo hacer yo mismo gracias de antemano.
Jul 21, 2008 | 2005 Volkswagen Jetta
Pixma MP160 not faxing
ERROR E27
Hola gente no lo consigo ni por un lado ni por otro.
Alguien lo ha conseguido ???
Sigo las instrucciones al pie de la letra:
Describo las teclas que he usado:
parar -> tecla en roja que tiene un circulo y dentro un triangulo
on/off -> tecla que pone on/off arriba
1- Pulso y mantengo pulsá la tecla de parar
2- pulso y mantengo "on/off" y suelto parar
3- teniendo pulsada "on/off" pulso dos veces para y en la segunda suelto para y on/off
4- la impresora se enciende y pone un cero en el contador
5- pulso una vez la tecla parar se enciendo la luz de la izquierda que es naranja la que esta con el triangulo y un rayo dentro
6- pulso otra vez para y la luz se va a on/off
7- pulso para otra vez la luz pa la izquierda es decir triangulo y rayo
8- pulso otra vez para (ya van 4 veces) y la luz pasa a on/off
y ahora que....
por que yo pulso ahora on/off y la impresora hace ruido pero la apago la vuelvo a encender y las luces de falta de tinta, es decir la de la B y la C siguen encendida
no se que hacer he mirao por todos los foros del mundo estoy a punto de tirarla por la ventana y comprarme otra
saludos
Apr 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
27 people viewed this question
k24674
jasbo
jasbo
