Question about Tivoli Kloss Model One AM/FM Radio
Radio tuner very noisy
See above
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
Tuning drifts
It sounds like the tuner is out of alignment. A number of things can cause this kind of problem. However, a realignment is a very costly proposition, especially when considering the used value of the Proton 320. If you really like this radio, you might want to try buying a used example off of eBay. They come up very frequently. Only... be selective. Don't pick anything from a seller without a lot of good feedback. And don't overpay ($50 tops).
May 08, 2010 | Proton R5A Clock Radio
Bought used truck he took out sterio but factory
That truck has a 3 piece system:
1. The display (located by heater controls)
2. The tuner (located under dash, above and to the right of the accelerator pedal
3. The EQ on some models and tape deck on others (located in center of dash)
Radio should work with tuner and display minimum
If the tuner is gone you are better off going aftermarket
Apr 14, 2010 | Car Audio & Video
I have saa7130 tv tunner card and i also install successfully above card but i have not a programme to run tv progarrme through cable but programme compatible to run the tv programme
please check back drivers tv tuner which has been fixed, if it was running perfectly or there is a miss, usually if the driver installed again the tv tuner can be used again. or for more open jelasanya tv tuner application and click on help, there you are given instructions in its use ordinances. thanks.
Feb 27, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
SI686
To activate the sound soother press the round button on the bottom left of the unit marked soother. To change the Soother stations press the "Tuner buttons either left or right. The tuner buttons are located on the bottom half of the unit above the volume buttons. one click of the tuner button moves one station on the sound soother selection.
Jul 06, 2008 | Sharper Image SI686 Clock Radio
Superadio noisy volume control
have you tried just cleaning them? even though they are probably supposed to be "sealed", most of them are not. if you purchase a can of pressurized tuner cleaner, radio shack used to carry it. saturate the volume control while turning it. i usually wrap the unit with paper towels as to not get the rest of the board. i also usually put on my safety glasses. you will see why. i am usually surprised as this works well with 90 percent of them i do.
Feb 19, 2008 | GE 35810GC3 (14 Channels) 2-Way Radio
Noisy video on tuner input
Well, if replacing the tuner did not solve it, the next likely culprit is the power supply. Does it look OK on A/V cable input? You didn't say what brand this is but all the older Matshushita made VCRs (panasonic, sylvania, quasar, magnavox ond others) have power supplies that fail often in this manner spewing out noise that interferes with the video signals. Some of us know how to repair the supplies as they are usually not available for replacement.
Dec 24, 2007 | Panasonic AG-1980 S-VHS VCR
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Tivoli Kloss Model One AM/FM Radio Logo
93 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Willem.
Willem.
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
