Question about Singer 8280 Mechanical Sewing Machine
Frequent thread breaking
I am experiencing frequent thread breaking while working with my Singer 8280 sewing machine. I have tried all the possible remedies to fix the problem but unfortunately was not successful. I would really appreciate your advice. Thank you
    Champion:
    Habit-Forming:
  • 201 Answers
Hai, Please check the thread tension and change the new thread and new needle. Otherwise put the some drops oil in the top and bobbin thread. Or go to mechanic shop.
Posted on Apr 16, 2014
  • 3 Answers
SOURCE: singer 132q sewing machine
I wanted to turn my daughters old jeans into shorts since they still fit, but were too short. I was having the same problem, but I was able to make some progress. I switched the thread from a poly/cotton blend to 100% polyester and it was a big improvement. I still was unable to stitch through seams. I am going to try a more heavy duty polyester thread and an upholstery needle (18/110).
Posted on Jun 21, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 139 Answers
SOURCE: How do I thread a Singer 6104 sewing machine
http://www.singerco.com/resources/threading.html Check out their threading diagrams, they are really helpful!
Posted on Apr 05, 2010
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
Why is the top thread on my Singer 1 constantly breaking after about 10 inches of stitching
When I've experienced this problem, I've found frequently it's because the top thread is wrapped around something (the spool pin, a thread guide, etc.) so there is something that will not allow the thread to feed smoothly. The thread stitches and stretches until it can no longer stretch and then breaks. I would remove the top thread completely from the machine and rethread from the beginning. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Check if the machine is threaded correctly. Also check that the tension is not too tight.
Feb 26, 2018 | Singer Sewing Machines
Singer sewing machine 8280 handwheel jammed while stitching. It will go backwards, but not forward, happened while sewing, thread jammed up. cleaned out but still won't advance.
Turn the hand wheel HARD in the direction it was traveling. Then remove the thread and the needle and run it full speed for 20 seconds to put it back in time.
Oct 04, 2011 | Singer 8280 Mechanical Sewing Machine
How to thread the machine and how to how to add thread to bobbin
you can download a manual for the 8280 from singer's website
http://www.singerco.com/accessories/manuals.html type "8282" into the search field and download it.
Apr 16, 2011 | Singer 8280 Mechanical Sewing Machine
I have been trying to thread the bobbin but my machine won't go all the way when I turn it toward me.pls help singer 8280
You could have a thread jam in the machine, try cleaning and lubricating and if that don't do it Call Singer at 1-800-4singer and see if it is covered under warranty.
Dec 30, 2010 | Singer 8280 Mechanical Sewing Machine
Thread mess at the underside of the fabric
Hi, maybe your bobbin is turning the wrong way and you need to flip it over. Or you don't have any top tension. Be sure the thread is in between the tension disks with the foot up. Its also possible that there is a burr on the hook part that goes around and grabs the top thread. The thread will catch on the burr and cause this issue. Usually after breaking a needle. Then the burr would need to be polished off.
Mar 18, 2010 | Singer 8280 Mechanical Sewing Machine
Singer 8280 is not giving me a useable stitch due to tension is not properly feeding resulting , no interlocking
Make sure that the thread is not getting caught on the handle. I was having the same problem and tried everything only to find that my thread was caught.
Oct 28, 2008 | Singer 8280 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
70 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
