Question about Pitney Bowes Postage Meter DM100i, DM200L, P700 - Ink Cartridge, Red
Error code 2309
Changed the ink cartridge and when the machine restarted it keeps giving error 2309 what do I try next?
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Lexmark X83 says 'Cartridge short press power key'. I've pressed buttons, checked cartridge, turned off and restarted. What next?
hi
have you replaced the ink cartridge prior to getting that error message? if so, you could have probably knocked out the encoder strip and need to relocate it. you can also try to use a water-moistened cotton swabs to gently clean the encoder strip.
i was not able to get a picture for lexmark but i hope this'll give you the idea on where to locate the encoder strip.
hope this'll help you
ciao!
Jul 23, 2008 | Lexmark Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
I just purchased a Canon Pixma MG6220 and during setup ~> (right after I installed ink cartridges) I received an error code 6C10 ~> telling me to power off printer and restart ~> when it restarts...
I Tried everything,then I had the print head in the middle and turned the printer upside down and shook,out fell a little piece of foam from one of the ink cartridge,now works great.
Oct 12, 2012 | Office Equipment & Supplies
Error 306 can't get printer to work with my mac. It was working just fine until I changed the cartridges and now it gives me an error 306
Error 306 is a communication error and should have nothing to do with the cartridge. Check to make sure the printer is plugged in and restart your computer, and try again.
Jul 25, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
ERROR CODE 3813
After I took out PrintHead and tried to clean it up again, I put it back in with Ink Cartridges and got error code 3813 - also couldn't fix it. Removed Ink Cartridges, turned printer off. Turn back on and it will forget about error code 3813 and will tell you to install Ink cartridges. Do that and error code 3813 is gone and ready to print.
A note: I did not find anything telling me I have to change printhead but my problem with black ink printing still exists so I will get new printhead and see if that problem gets fixed.
Sep 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
ERROR MESSAGE
please check and clean the unit where ink cartridges are located
Sep 21, 2007 | HP 920 Plain Paper Fax
Pitney Bowes Postage Meter DM100i, DM200L, P700 - Ink Cartridge, Red Logo
51 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Victorman
Victorman
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
