Question about Ovens
Oven making loud ringing sound although alarm not on. think it may be the fan
Lamona hja 3400
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
barkencoa
  • 3463 Answers
SOURCE: OVEN MAKES A LOUD NOISE WHEN IT IS TURNED ON
This indigates worn or tight fan motor bearings, if it is a built in oven , then it could have an external cooling fan in addition to the oven fan, so you will have to determine which one it is.
Usually it means having to replace the offending fan motor, as lubricating only provides a short term solution.
Hope this helps.
Posted on Jan 09, 2010
How do i replace the drop hinges for the oven door on a lamona HJA 3400
You will be taking the whole door apart to do this task.
You may need to improvise some tools and equipment, as the door-closing springs are pretty tough.
God bless your efforts.
Apr 30, 2018 | Ovens
How can I clean the inside of the glass on a Lamont 3400 oven door
Hello, Johnny -
The instructions I found for cleaning the glass inside an oven door are generic and not just for a Lamona brand oven. (You did mean "Lamona" and not "Lamont", didn't you?)
See the instructions here:
https://www.mom4real.com/how-to-clean-in-between-glass-on-your/
Read through the instructions, in full, first.
This is a link to other instructions in video format:
https://www.todayshomeowner.com/video/how-to-clean-inside-the-glass-on-an-oven-door/
Best wishes.
Mar 07, 2018 | Ovens
Where can i buy a new outer glass for HJA4610 Lamona as mine has exploded?
Have a look at https://www.howdens.com/appliance-collection/ovens/lamona-double-fan-oven/
Oct 07, 2016 | Ovens
How do you remove and adjust the oven door to sit squarely on the rubber seal Its a Lamona HJA 3220
open door half way,pull out on the door,it will slide off the hinges
May 09, 2015 | Ovens
Got a fan assisted oven Lamona 3400 in operation back heats up front dont?
does it use different elements for back and front? check for continuity. is fan working properly?
Mar 10, 2015 | Ovens
No temperatures on the oven
Easiest thing to do is to Get your Model Number, log onto www.searspartsdirect.com and order the new knobs... Or go to your local appliance repair center or Appliance parts store and order them and you will be able to get fix it for the future.
Download LAMONA HJA 3300 HJA3300 User Guide English
Mar 03, 2014 | Ovens
Model HJA 3220 removal of internal glass panel
i have the manual if any one needs it... can't upload it here but email me if you want... faisal at citydealestates dot com - no spaces. covers HJA3220 HJA3320 and HJA3212
Feb 18, 2012 | Ovens
Has anyone had a problem with the inner glass on the Lamona oven door exploding. Mine just has! It's only 18 months old and hardly used. I wonder if it's the difference in temperature betweeen the hot oven...
We bought our kitchen from Howden's as well about 15 months ago. They installed a Lamona double oven and hob. Last night when opening the door to the bottom oven our glass on the inner door exploded as well. Maybe there was a batch of defective ovens as ours sounds as though they mat have been bought/manufactured at the same time.
Mar 07, 2011 | Ovens
Ovens Logo
14 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
