Question about Good Technology Good for Enterprise
How do I find Preferences in the Good APP for iPhone
Need to update my signature and cannot find Preferences menu
How do i apply the signature drawn up in Outlook?
From Outlook 2011 (for Mac)'s help:
You can set a default signature for each of your mail accounts.
  1. On the Outlook menu, click Preferences.
  2. Under E-mail, click Signatures .
  3. Click Default Signatures.
  4. Under Account, select the account for which you want to set a default signature.
  5. Under Default signature, click the pop-up menu in the selected row, and then click a signature name.
Note If you have multiple accounts, you must set the default signature separately for each account. If you open Outlook's Help and select Signatures and Formatting and look around for what you need.
Oct 09, 2014 | Apple MacBook Air
How do I set a signature on my text messages?
Sadly, this is not possible. A simple solution to this problem is to type what you would like your signature to be in your notes app and then copy and paste it into the message.
Oct 06, 2014 | Apple iPhone Smartphone
Iphone 5 face book, insta gram, twitter and pandora are shaded
The icons are greyed out because the app is unusable while it's waiting to update. The phone can hang up when updating if you're on a slow connection for too long. The first thing to try would be to delete the app and try reinstalling while on a good Wi-Fi connection. If that doesn't work, try powering the phone down completely (hold the power button down until the the red slide shows up) and turn the phone back on. If that's *STILL* not enough, you may need to reset your phone. In most cases, that first step is generally all you'll need. Good luck!
Aug 15, 2014 | Apple iPhone 5
IPhone weather app "update failed'
The easiest way is to wait for a few hours and try to update your iPhone again. Best remember to try this way because sometimes it really works well. And simply, I would like to introduce the steps to upgrade your iPhone via WiFi environment first and foremost.
1. Open Settings of your iPhone.
2. Connect WiFi and find General on your iPhone.
3. Open Software Update.
4. The device would automatically check for update, or you could click the "Check for update" button.
5. After that, click Install Now button. Then you just need to wait until the update completes.
http://www.leawo.org/tutorial/what-to-do-when-iphone-software-update-failed.html
Dec 20, 2012 | iPhone Apps
How to change your signature on a g1
The non-gmail mail app does not support changing the signature on the version of Android OS that is loaded onto the HTC Dream/G1. In the Gmail app do the following:
1. push the menu button to bring up the menu options for the Gmail app.
2. select settings from the menu
3.select signature and enter your desired message
4. press OK to save or cancel to void your entry.
Mar 02, 2011 | HTC G1
I recently updated my ibooks app for the iPhone 3 and now it will not open. Any suggestions?
This is a common bug when Apple upgraded the ibooks.
First, delete the app from your phone. Second, open itunes on your computer without the phone attached third, update all apps fourth, plug in your iphone and sync ibooks
if the above doesn't work then re-download ibooks from itunes
if both above dont work then you need to erase the ibooks app from your phone and itunes and then download the app again.
good luck!
Feb 12, 2011 | Apple iBooks
When i plug mi iphone up to mi computer it doesnt give me the option to update the itune app! what should i d to get it to work?
it will not give you the option...
you update itunes on your laptop only... and if their is a itunes update the the iphone the phone will do it thru the app store on the phone
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Apple iPhone 3G
Is there an Englishdictionary application which suite my iPhone?
iphone 3G English dictionary download-WordBook app. WordBook is a powerful iphone 3G dictionary app,developed by TranCreative Software. it is the most downloaded commercial english dictionary in Itunes app store.WordBook does not require an internet connection to run. WordBook text sizes and other preferences can be modified in iPhone Settings.
Sep 06, 2010 | iPhone Apps
How can i put music on my iphone using itunes
1. Open iTunes. Open the Edit menu on Windows or the iTunes menu on a Mac. Click the "Preferences" option. Make sure the "Disable automatic syncing for all iPhones" check box is selected.
2. Plug your iPhone into the computer and wait for iTunes to recognize it. Click on your iPhone's icon on the right side of the iTunes window. Click the "Music" tab.
3. Select the music you want to sync to your iPhone using playlists. You can also select the option to sync all your music to the iPhone.
4.Click "Sync" when you're done customizing your settings.
Get more details: Transfer music files from Mac to iPhone
Nov 05, 2009 | Apple iPhone Smartphone
Good Technology Good for Enterprise Logo
124 people viewed this question
Top Good Technology Apps Experts
shuyumeng
shuyumeng
Alan Gsm
Alan Gsm
Level 1 Expert
Are you a Good Technology App Expert? Answer questions, earn points and help others
