Question about HP LaserJet 2840 All-In-One Printer
HP 2840 printer pause will not resume The following steps do not work as the status resets to 'paused' in seconds. Open System Preferences and click Print & Fax. Open Print and Fax preferences Select the printer in the Printers list, and then click Open Print Queue. Click Pause Printer or Resume Printer to stop or start all print jobs in the queue.
    Guru:
  • 224 Answers
Uninstall your printer and then re-install it that should fix your issue,it could be a bad version of an updated driver that is causing the problem
Posted on Jun 19, 2009
My printer status says it is on pause and it won't print. How do I get it off of pause?
I'm assuming that you're using a Mac. Try to uninstall the Lexmark driver first then download an updated driver online: http://bit.ly/McHL54
If it doesn't work, try to reset the printing system:
  1. Open System Preferences and click "Print & Fax". Then click or right-click on the blank space around the list of printers on the left-hand side.
You should see a pop-up menu and the option to "Reset printing system...". Once you select the option, the OS will restore the CUPS printing system back to its original default settings. NOTE: This will, of course, erase all of your print queues.
Then add a print queue manually: http://bit.ly/SxD5Za
Aug 08, 2012 | Lexmark 90T9105 - Pro 901 All-in-1
The HP laserjet 1012 printer has the online print status: "paused". I click resume and it goes back to pause. How do I troubleshoot this? The printer is on a shared network.
load the drivers in another system locally..check..if problem solved un install the divers reconnect & check..
If problem presists replace formatter..
Sep 06, 2011 | HP LaserJet 1012 Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
My hp printer is stuck on pause. I need free help to get it off of pause. Thank you. I tried run and tried to create a notebook but that did not really work out very well. Or else I didn't do it very well....
I went to Control Panel, then Hardware and Sound, then Printers, then double clicked on the word "Paused" under my printer's status and clicked "Resume Printing" -which worked for me when my HP printer was stuck.
Oct 13, 2009 | HP Compaq dc5700 Microtower - Free Flat...
HP 1020 black white printer not commencing printing. Looks like paper pickup is not working. Computer connection is fine, etc. startup noise when I turn on printer also OK. Just refuses to start jobs in...
Dear Sir,
According to your problem it seems to be your printer paused,to resume this go to settings>then printer and faxes>confirm your printer status as ready,if it is paused right click on printer icon then cliak on resume.
If you had any problem post a feed back we were happy to assist you,
Have a nice day
Sep 17, 2009 | Office Equipment & Supplies
Frequently changes its status to offline; have wireless connection
please perform the steps below:
Step 1:
Determine if the printer is paused or offline :
1.Open the printers folder, if necessary.
a.Click the Start icon.
b.Click Control Panel.
c.Click Hardware & Sounds.
NOTE: This step is not required when using Classic view in Windows Vista.
d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2:
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Aug 12, 2008 | HP Photosmart C7180 All-In-One InkJet...
Blinking Resume Light
i think the problem is that the printer could not initialized the printer head position. you can open the cover and turn on the printer. check if the motor for feeding paper moves but the roller does not. replace the gear attached to the roller. i hope this will help.
Jul 24, 2008 | HP DeskJet 612c InkJet Printer
Hp 2300 laserjet printer error code 13.20.00
this problem persist NVRAM resetting
To perform an NVRAM initialization, complete the following steps:
1 Turn off the printer.
2 Press and hold (DOWN arrow), and turn on the printer.
3 When all three status lights are lit, release (DOWN arrow) and press (UP arrow).
4 Press PAUSE/RESUME. The first item of a menu appears.
5 Use (UP arrow) or (DOWN arrow) to scroll to NVRAM INIT, and press (SELECT).
cihat ALTIN FROM TURKEY ANKARA
Jul 16, 2008 | HP LaserJet 2300d Printer
My printer says it is offline and now it wont print
perform the steps below if the Operating System is XP
Step 1:
d.Click Printers.
3.Click Printer.
Step 2:
Nov 28, 2007 | HP DeskJet 340 InkJet Printer
HP LaserJet 2840 All-In-One Printer Logo
822 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
