Question about Coleman Heating & Cooling
Run for 1 minute only
Run for 1 minute and stop after
    Genius:
  • Coleman Master
  • 1,363 Answers
Try changing capacitors
Posted on Sep 15, 2015
What would make a 865 Turbo run for 1 minute and stops? It restarts and runs for 1 minute and stops?
Hey. Couple of things come to mind. If the catalytic converter (or muffler, usually the cat) is mostly blocked, the car will only run a very short time and then quit due to exhaust backpressure. A mostly blocked gas filter will cause a similar situation.
Sep 05, 2014 | Cars & Trucks
Runs for 2 mins. then stops, push reset button & will run for 2 minutes & stops again
How long have you had the dryer? It sounds like it is overheating, and the most likely cause is accumulated lint. You can check this by removing the round plastic covers on either side panel. Just rotate them and they will pop out. Clean out any lint you see in the air channels and replace the covers.
Also check your ducting - it may be partially or fully blocked by something. You could test this by disconnecting the ducting, then running the dryer to see if it still shuts off. (Prepare for some loose lint flying out in this event.)
Jun 01, 2009 | Asko T701 Electric Dryer
It runs and there is heat but after 1 or 2 minutes it stops
rosalinda_ta la secadora es de gas o es elecrica tambien necesito por favor el modelo y la serie adjunto con el año de la misma.
Gracias estamo aqui para ayudarte con todo gusto.
Espero tu respuesta.
your reting is important for me
Was this helpful?
May 19, 2009 | Whirlpool Dryers
Dryer stops and flashes E2 failure
Try unpluging your dry for about 5 minutes. Sometimes it just needs to reset itself.
Jan 31, 2009 | Kenmore Dryers
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
My GE washer Model WPSR3100 will run for 2 or 3 minutes when first started and then stop. After 5 or more minutes it will start up again and run for less than 1 minute and stop again for another 5 or more...
It appears that you may have controller issues since operation is haywire. Try to reset the electronics to factory defaults. If this remedy does not do it then.........
Search Over 2 1 Million Appliance Parts
Sep 20, 2017 | GE Washing Machines
Clock will run down to 1 second of the minute and microwave will stop
The surge probably didn't cause this. This common error indicates a problem in the convection damper circuit. It may be a defective damper switch, damper motor, or a jammed damper door. I have attached a drawing of a typical damper system. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Sep 21, 2007 | Dacor PCOR30 Convection/Microwave Oven
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
