Question about Sewing Machines
Picking up the bobbin thread
My machine suddenly started skipping stitches and now refuses to pick up thread from the bobbin. I've changed threads, bobbins and needles. I've thoroughly cleaned the bobbin case. I need to finish this dress. Help!
  • 8 more comments
  • edra Nov 06, 2007
    i have a singer model 57825c and the i have a bobbin thread problem. the needle won't pick up the thread. it was working the it quit. what is the problem?
  • Anonymous Nov 21, 2007
    I have a toyota sewing machine and it has for some reason stopped picking up the bobbin thread. How do I fix this? Many thanks for any suggestions.
  • Anonymous Mar 26, 2009
    how to thread a toyota machine?
  • Anonymous Apr 02, 2009
    Top thread won't pick up the bobbin thread and my stitches get skipped. The lack of an instruction manual kills me!
  • Jimmie Sill Dec 17, 2013
    First thing. Replace needle. Check if this works. Second. Remove the total bobbin assembly to adjust the bobbin tension. Place your bobbin in the assembly with the thread going away from the spring. Place the thread under the spring. Now, carefully allow the assembly to dangle. Bounce up and down slightly to make the assembly move. If it doesn't move down about one inch it is too tight. You must loosen or tighten the tension until this happens. While this assembly is out place one drop of oil on the race where the assembly came from. Now reinsert this assembly. Place the top tension on about three. Use trial material and sew slowly to see what happens. The top and bottom amount of thread should be tightening in the center of the fabric. You will have to adjust the top tension to do this. If this doesn't fix it then you probably have to get it timed. You can also do it yourself by watching a video that is offered on the internet. (How to website I believe)
  • Anonymous Mar 18, 2014
    on a singer 403 with top loading bobbin, when the thread gets hooked and starts to rotate, instead of sliding over the lip of the bobbin case to make the stitch, it manages to slide under the lip of the bobbin case resulting in a mess and no stitching. I've cleaned it thoroughly but no change. Wonder if the bobbin case needs to be replaced?
  • Anonymous Mar 19, 2014
    Bobbin thread not stitching?
  • Anonymous Mar 23, 2014
    Need help how to thread the bobbin
  • Anonymous Mar 26, 2014
    machine not picking up thread when using a small gauge nbeedle
  • Jimmie Sill Nov 18, 2014
    Timing of the bobbin is my first thought. If you look under the needle plate and turn your hand wheel towards you then watch the hook (pointed thing under the bobbin). It should pick up the top thread as the needle is moving upward. If it doesn't then you know your timing is wrong or your needle length needs to be adjusted. For these you will need to go to you tube to learn this or go to your local repairman.
  • 41 Answers
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
I found the Instruction manual directley at the Singer Home site .
Go to :
Posted on Nov 20, 2010
Thread started bunching on underside of project & tangling around bobbin. Now the needle won't pick up bobbin thread, even after changing needle 2x and re-threading upper thread. What's wrong?
Hmmm, could be several things.
Try a brand new needle. Try a different brand of thread.
Remove the top thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still will not pick up the bobbin thread, the machine could be out of time.
Jan 19, 2018 | Singer Sewing Machines
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
My New Home L372 sewing machine is dropping stitches
skipped stitches
1. the needle is incorrectly inserted into the needle holder
2. the needle bent or blunt
3. Machine is not threaded properly, rethread using every thread guide
4. Wrong needle for the fabric being sewed
Mar 22, 2016 | New Home Sewing Machines
I have a XL2600I and the top thread is only picking up the bottom thread about every inch. What can I do or replace?
try a new needle--use the right needle for the fabric being sewed
rethread the machine, using every thread guide
take the bobbin out of the bobbin case and reinsert it, making it sure it counter clock wise in the bobbin case
also could be a timing problem
Mar 15, 2016 | Sewing Machines
Needle not picking up stitches
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
How do I sew denim and heavy fabrics?
Why is my bobbin not winding evenly?
Why won't my machine pick up the bobbin thread?
Why is my machine skipping stitches?
Why is the thread looping/bunching under my fabric?
Why is the thread looping/bunching on top of my fabric?
Why doesn't my stitch pattern match what is on my machine?
How often should I oil my machine?
What types of thread should I use?
I can't see the take-up lever? o
May 16, 2015 | Janome Sewist 525S Mechanical Sewing...
How do I thread the 960 Bernina Bobbin?
I'm assuming you have a front loading bobbin. Look at your bobbin. Hold it so the thread is falling down from the top to the right side. Slip it straight in to your bobbin case, and pull up through the slit, until it snaps in through the side clip.
Generally, if you are missing stitches, the hook isn't picking up the thread from the needle, and you will need to take it in for service at a Bernina dealer.
Mar 03, 2015 | Bernina Sewing Machines
Machine just quit picking up bobbin thread and sewing in the material. It is just making holes in the material.
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Needles need to be replaced every 2-8 hours of sewing time, on average, or about 1 needle per garment. A needle that has hit the presser foot or needle plate is "dead", and needs to be replaced to (and eventually, you'll need to buff out the rough spots on the presser foot, and needle plate).
Common causes of skipped stitches (stitching that looks like
_ _______ _ _ _______ _ _____________ instead of _ _ _ _ _ _) or of not picking up the bobbin thread are: dull or damaged needle, needle in backwards, needle not fully up in the needle clamp, needle too small a size for the thickness of fabric, dirty machine, misthreaded machine, and way, way, way down on the list, machine out of time.
Jan 14, 2014 | Singer Sewing Machines
Sewing machine not stitching
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
it's also possible that the machine needs to be serviced
May 31, 2012 | Singer Sewing Machines
Needle not picking up bobbin thread on Prolectrix 8 stitch
my machine is not picking the thread from down bobbin thread ,i am fallowing the all instruction for threading.
Jul 21, 2009 | Sewing Machines
Sewing Machines Logo
1,222 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
