Question about Whirlpool LER5636P Electric Dryer
Drier was working O.k . Timmer Stop working And so did the Heating. Does the Timmer control Temperature aswell.?
  • 6,784 Answers
Yes, if the timer mech is damaged and, it will not rotate, this is cause the heating cycle to become inoperable. the time is responsible for initiating the heating command and the thermostat helps with the temp regulations. replacing the timer will restore the normal functions of your dryer.
Posted on Jun 18, 2009
Underfloor heating wont stop running
Look for a stuck relay that controls the pump
Dec 30, 2013 | Hunter Mechanical Heat & Cool Thermostat...
Timmer switch turns on but pump does not start. I have to go out and turn off timmer swith for a few seconds and turn timmer back on and pump usually starts auto matically. Some times when timmer switch...
The flashing re light is trying to tell you what is wrong! It will flash 2 to 9 times and you need to count the flashes and then refer to the troubleshooting chart on page 27 of your owners manual.
To me it sounds like your pump loses it prime some I would suspect a leak on the suction side of the system.
http://www.inyopools.com/manuals/210/IntelliFlow4x160_OM.pdf
Jul 20, 2011 | Pentair 4-Speed 230v IntelliFlo 4x160...
I've located the thermal fuse on the blower housing and there is no continuity. Next to it is the drier thermister and I have no continuity there either. If I replace the fuse where do I go from there?...
The thermal fuse is blown open due to the thermistor being open (no continuity). The thermistor is a negative temperature coefficient resistor in which the resistance varies inversely with the temperature. Since the thermistor is open (infinite resistance), the electronic control board "thinks" the dryer temperature is too low. It then activates the heater relay continuously which makes the dryer overheat and blow the thermal fuse open to stop the motor which eventually turns off the heating element. Replace both the thermal fuse and the thermistor and it should your problem. They are manufacturer part numbers 3392519 and 8577274, respectively. The part numbers AP3132867 and AP3919451 are used only by www.partselect.com.
Apr 01, 2011 | Maytag MED9700S Electric Dryer
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Timer does not move in Auto/delecate
Im guessing there is another thermostat in the circuit to actuate the timer motor circuit. If you can find the timer motor wires check for voltage in the run (cycles yuor having trouble with) modes. Automaticadvance timmer mode is usually an open set of contacts and close when the element is heating too correct temperature allowing power to continue to the timmer motor. In the delicate cycle often it is the same thermostat on a differant set of contacts (but they could be on the same thermostat this type of thermostat has 3 termjinals usually 2 on 1 side and 1 on the other). that energize the timer motor.
The other thing that could be the problem is the timmer itself. There has to be a set of contacts inside the timmer that energize the timer motor in both cycles. these are or can work on some cycles but not others due to worn out parts in the timer. Check for voltages her that corrospond with your timer motor.
Hope this helps Please rate me accordingly and GOOD LUCK
Mar 08, 2009 | Amana ALG443RAW Gas Dryer
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Washing machine gone crazy
Does the timmer advance at all? Timmer motor. on timmer if timmer not advancing.
Mar 30, 2007 | Frigidaire GLWS1233A Top Load Washer
Whirlpool LER5636P Electric Dryer Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
