Question about Sony Cyber-shot DSC-W80 Digital Camera
Zoom will not work at all get error turn off camera
When I try to use the zoom button it gives me the error Turn the power off and on again. What can I do to possibly try to fix this?
  • 4,234 Answers
The unit attempts to get the lens into a known position when the power is first turned on. If this fails to complete properly, the message you see will be displayed. It is hoped that the power off/on/reset will cure the problem. Since the message appears all the time, the zoom/fucus motor is either stuck or the mechanism is jammed. Some people say to gnetly tap the side of the unit while the power-on sequence is running. This may be enough to release the gearing. Short of that working, I would recommend that you take this to a service center. They will clean and relube the gears inside.
Dan
Posted on Jun 18, 2009
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
Cant zoom
lens stuck error, probably a broken gear teeth.
Jul 15, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
The lense will not zoom
Your camera has a zoom failure that can not reset by pushing menu buttons or else. Ask your local Sony repaircenter.
Regards,
Rob NL
Apr 24, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Wont zoom
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Zoom error
I had the same problem with mine and I tried several suggestions, BUT the only one that has worked is to gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur. Another note. I had tried this several times until I finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Dec 09, 2005 | Fuji FinePix E550 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
155 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
