Question about GE Ohmeda TuffSat Blue Oximeter - Pulse
Prb shows up on screen
Flashing
THE LIGHT TURN ON BUT DOSNT DO ANYTHING YOU CANT SEE ANYTHING ON THE SCREEN
do the following 1.check if the monitor power cable is fixed good.
2.try to connect your cpu to another monitor and see if its working.(if it works no prb with the video card else prb with the video card)
3.if your video card is good .then there must be a prb with your monitor a little soldering will fix it !!!
Jun 14, 2011 | Dell OptiPlex GX620 PC Desktop
When I take a photo, it just shows white on the screen and each photo is white when I view them. However I can still take videos just fine! whats wrong with it? It is a Samsung ST50
Hi you have very interesting problem. It seem to me just lens unit defective. What I can tell between camera picture mode work and video mode work are depend on how mechanical shutter unit and electro shutter signal work. It is kind of technical thing to figure them out. Maybe I am wrong, but I sure also. Thanks and best regard!
May 24, 2011 | Samsung Cameras
I have a TI-30XS and I can't figure out how to do factorial problems
Press the prb key. You are offered two menu options PRB and RAND. The factorial function is the third choice under the PRB menu.
Exemple. Calculate Factorial 4.
4 then prb key, then 3 , then ENTER key. Screen should show 4! and the result is 24.
Hope it helps.
Nov 03, 2009 | Texas Instruments Office Equipment &...
What key do you use when calculating factorials? In my math book it shows 9 x! or 9!. I cannot find this key on my TI calculator.(!)
The prb key displays two menus PRB and RAND. The factorial is the third option under the PRB menu.
4 PRB 3 displays 4! which is 24.
Hope it helps.
Oct 04, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Prb flashes on the control panel
http://www.google.co.in/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Flib.store.yahoo.net%2Flib%2Fusappliance%2Fwalloven-manual.pdf&ei=j0mISrCgM8iOkAWFy5ihBw&usg=AFQjCNFa_wAnlQ4ip23MwFztIYTXiyDC8Q&sig2=7gUbH8QmlLQ-PASP5zxJZQ
Hope this helps.. Please rate me!!
Aug 16, 2009 | Ovens
My philips go gear is not recognized on my computer. I cannot put music nor delete music. when i charge it it use to be a computer on the screen saying do not disconnect now my screen is black with a blue...
the solution for this prb s...u better install the driver cd came along with u r philips no gear..and reinstall it..then u try cinnecting it through USB...u r comp will automatically detect the philips removable drive...if it cannot detect u r philips set..then it must be a prb with u r mother board..u should reinstall all the driver cd came along with u r mother board...then try it will work for sure...its a common prb with all of the users...if u hav prb with installing the STEP 2 process...u can better call u r computer engineer for installing the mother board driver cd...STEP 1 process can be done by urself!!!!
Jul 24, 2009 | Audio Players & Recorders
Init local mode faild
yes it is comon prb just use easy cable its 100% solve your prb
Apr 11, 2009 | Nokia 1208 Cellular Phone
Oven constantly beeping
PRB refers to the power relay board.It is not an error message.Probably the PRB is damaged and needs a replacement.All the best.And please do comment as to how else i can help you.
Jan 15, 2009 | Ovens
GE Ohmeda TuffSat Blue Oximeter - Pulse Logo
191 people viewed this question
Top GE Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a GE Measuring Tool and Sensor Expert? Answer questions, earn points and help others
