SOURCE: My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
SOURCE: dishwasher runs for 5 mins than stops with alarm &...
Refer user manual.
Also check your water inlet for free flow.
SOURCE: fisher and paykel nautilus dishwasher
Does it fill with water? I would guess a fill/ drain/ heating problem. See if you can eliminate any of those.
SOURCE: My GLD4464Rss GE dishwasher start the cycle, water
There is a temp sensor that tells how hot the water is and it is either bad, or the heating element wont warm the water so it drains.
