Question about Canon Pixma MX922
How to set up fax on canon pixma mx922 - Canon Pixma MX922
rhoncruz
  • 134 Answers
SOURCE: canon pixma mp530 all-in-one printer set up
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Solution: Changing the TX report MP530
Change the TX Report 1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [ left.gif] or [ right.gif ] to select [TX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif ] to select [TX REPORT] then press <OK>.
4. Use the [ left.gif] or [ right.gif ] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ left.gif] or [ right.gif ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before printing, confirm that the location where you have loaded paper is selected as a paper source. Press <Feed Switch> to change the paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
computer.
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use leftright.gif to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
sizetypelcd.gif 3 . Press <OK>.
4 . Use leftright.gif to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note: In order to obtain optimal quality print results, when copying photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus Glossy.
5 . Press <OK>.
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left.gif] or [ right.gif] to select <USER SETTINGS>.
3. Press [OK] two times.
datetimeset.gif 4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ left.gif] or [ right.gif] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
Posted on Dec 01, 2008
websnail
  • 419 Answers
SOURCE: Can't send fax on Canon pixma mx310
There are two buttons on the MX310... one for colour and one for black & white.. Depending on which mode you're using (ie: copy, fax, etc..) these buttons will copy, fax, etc...in either colour or black & white accordingly.
These buttons are located on the far right of the control panel with colour closest to the user, black & white above that and then the stop button above and right.
To fax in black & white (or mono as it's otherwise called) just choose the Fax mod, then press the Black button and you're away...
Hope that helps.
Posted on Feb 13, 2009
  • 240 Answers
SOURCE: I need help setting up the fax option on my Canon Pixma mx310
maybe you've done a mistake of installing the driver of the printer...try to uninstall and reinstall the driver of the printer...and set up the fax .
i hope it help
Posted on May 13, 2009
iservice
  • 318 Answers
SOURCE: canon pixma mp 830 on my fax activity report I
Yes,it means the fax did not go through,it will show OK on the report if it was succesfull
Posted on Jul 03, 2009
SOURCE: Canon Pixma MX860 fax problem.
Switch to telephone priority mode. Hook your answering machine to the other phone jack on the printer.
Posted on Feb 26, 2010
Canon mx922 when faxing erro tx report comes back result ng
Since you do not have a dial tone, please ensure that the line coming from your telephone source is plugged into the LINE jack on the unit. If you are connecting a telephone or answering machine to the unit as well, you will want to plug them into to the EXT jack on the unit. Please ensure that the unit is turned off when connecting the telephone line and telephone/answering machine to the unit. More information on connecting the lines and devices to your computer can be found
Once these items have been verified, if you still are unable to hear a dial tone when you press the HOOK button on the unit or are unable to send a fax, please call or email us using one of the methods on the page for further assistance.
Canon PIXMA MX922
Apr 04, 2017 | Canon Pixma MX922
Color photos are really off color.
Hi George!
Are using Genuine Canon Ink & Paper?
Here are some links to your printer troubleshooting videos etc.
Canon Support Drivers PIXMA MX922
Jun 30, 2015 | Canon Pixma MX922
Canon pixma mx922 will not send fax error
The connection is through the rj11 port to your phone socket. Sorry if that sounds odd, just checking as a first step.
Jun 18, 2015 | Canon Pixma MX922
How do I download a user manual for Canon Pixma MX922
Hello, For watch the online manual you can use the given link. http://www.manualslib.com/manual/430848/Canon-Pixma-Mx922.html
Feb 10, 2015 | Canon Pixma MX922
How do I get a paper conformation for faxes on a cannon mx922
From page 98 of the fax users manual:
"This report is printed after each fax reception.
• At the time of purchase, the machine is set so that RX REPORT is not printed at all.
You can set the machine to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings."
You should have the manual on the cd that came with the printer. If not try the link listed.
Canon Consumer Home Office PIXMA MX922
Dec 22, 2014 | Canon PIXMA MX922 Wireless All-in-One...
Fax instructions
You can download a copy of the manual here:
Just select your operating system (Windows or Mac) in the Brochures and Manuals section then, click on the "I have read..." disclaimer box to checkmark it then, click on the Download button.
Oct 26, 2014 | Canon Pixma MX922
What are the steps to send a fax on Canon MX9222?
Hi
unless printer is already in fax mode, press the FAX button, then enter the fax number and press either BLACK or COLOUR button.
good luck
Sep 18, 2014 | Canon Pixma MX922
Canon Pixma MX922 Logo
old marine
old marine
