Question about Evolis PEBBLE 4 Led Card Printer
Hand symbol on evolis pebble 4 - Evolis PEBBLE 4 Led Card Printer
  • 54 Answers
SOURCE: Evolis Pebble Cleaning Kit
Check if feedr Roller is moving.
Look at backside of printer . There is a card thickness adjustment lever where you feed the cards . Make it positioned at 1 mm.
Posted on May 21, 2008
SOURCE: evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Posted on Aug 07, 2008
SOURCE: We have Evolis pebble printer
The printer is waiting for a card to be inserted. The printer has a manual card feeder option, insert a card into the printer.
Posted on Dec 14, 2010
  • 54 Answers
SOURCE: I have an Evolis Pebble
Just check for thickness adjustment pointer near card feeder . It should be 0.8 for standard cards.
Check in driver settings also if you have selected for manual feeding.
You may need to clean the Roller situated at feeder.
Posted on Apr 13, 2011
  • 54 Answers
SOURCE: My ink ribbon breaks after
Clean all transport rollers . check for X offset by giving Rx command in Properties/Tools/dialoge with printers. Increase offset little bit using Px command
Posted on Apr 27, 2011
Pebble 3 windows 8 driver
Use the pebble 4 driver. I am using windows 10 and have tested on 8 as well. Download the Pebble 4 windows 8 driver and it will work fine.
Mar 19, 2014 | Evolis Pebble Color Card Printer
Evolis pebble 4 shows the end of ribbon light...
Not card, not ribbon, not cleaning, not driver setting.
Does your black ribbon roll and never stops?
Sep 10, 2012 | Evolis PEBBLE 4 Led Card Printer
I have an Evolis Pebble 4. For each card printed, a white thin streak appears. This streak cuts through the entire card.
Try cleaning your printer first using the Evolis A5011 Cleaning Kit. If the line is solid and goes across the length of the card, you might have a burned/damaged pixel. Check with Evolis or your Evolis Card Printer supplier for warranty information, your printhead might still be under warranty.
-- The Pros at www.DiscountIDStore.com
Aug 28, 2011 | Evolis Pebble Color Card Printer
I'm using Evolis Pebble 4 to print card, i wish to let the printer flip the card itself and print at the back of the card. So i first set the duplex of the printer to vbPRDPVertical on VB6, and then i...
Dear Sir,
Evolis pebble4 printer is a single side card printer . It doesn't has mechanism to flip the card.
If you want to flip the card automatically you must go for Evolis Dualys or higher model.
Apr 04, 2011 | Evolis PEBBLE 4 Led Card Printer
Fault light showing hand is lit - what does this mean please ? Evolis Pebble 3 ID card printer
It means you need to insert a cleaning card for cleaning cycle of printer.
Open printer properties Click on Tools tab click on Printer self cleaning button. You will get a new dialog box asking to remove ribbon and cards and insert a cleaning card in feeder.
Insert a cleaning card in feeder . Adjust thickness pointer to maximum remove ribbon and just cleck to proceed for cleaning.
Mar 31, 2011 | Evolis Pebble 3 ID Card Printer Package...
Card are stuck in evolis perbelle 4 so we get it by hand and then we have mechanical issues
First check for your card's thickness and adjust thickness lever accordingly.
Take a soft cotton cloth soaked with Isopropyl Alcohol with minimum water content.
Clean all Rollers including one roller below the feeder.
For cleaning Rollers you can take out ribbon and press the push button on front panel.
This will move Rollers and you will be able to clean rollers easily.
Clean the rollers below ultraviolet ribbon sensor and the roller set at output hopper also.
Feb 02, 2011 | Evolis PEBBLE 4 Led Card Printer
I have an Evolis Pebble 4 printer. I am trying to print out cards from the Pebble 4, but the machine is not pulling the cards from the card holding tray. Because the cards are not being pulled from the...
Oct 14, 2010 | Evolis Pebble Color Card Printer
My ink ribbon breaks after it prints 2 cards. I have an Evolis Pebble 3.
Aug 04, 2010 | Evolis Pebble Color Card Printer
Evolis PEBBLE 4 Led Card Printer Logo
47 people viewed this question
Top Evolis Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Fred Block
Fred Block
k24674
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
