I had repairs done to my TV, but it was not properly set up and the picture is tilted to the left. How can I get to the screen where this can be adjusted.
  • dandkw Jun 21, 2009
    my TV os a RCA model D52W17BYX1
    Dave
  • 10,594 Answers
Usually TVs have tilt adjust option in Menu and you can adjust picture tilt in some degree.
Let me know exact model and brand of TV to provide you more accurate info about tilt problem.
Thanks.
Posted on Jun 18, 2009
  • Shahid Electronics
    Shahid Electronics Jun 21, 2009
    To go to service menu in RCA, follow below procedure..
    1. TV turned on
    2. Press and hold the 'Menu' button at the tv.
    3. Press and release the 'Power' button.
    4. Press and release the 'Vol up' button.
    5. Release the 'Menu' button.
    6. The initial security parameter displayed will be 'zero' Change this to '76'.
    7. Use the 'Channel up or down' to select parameter 'P'.
    8. Write down the old value of the parameter before changing.
    9. Use the 'Volume up or down' to change the parameter value.
    10. When you have made all the adjustments you want turn the set off to exit.
    Thanks.
My tv says no picture
please follow the steps. God bless you
No picture
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Sep 24, 2013 | Televison & Video
Our HD52W59 HDTV comes on but slowly fades away to an all black screen. Audio is good but no picture. What is wrong?
I should be able to help you. First and very important. Do not keep trying to turn the tv on. If the hold down capacitor has broken free you could damage one of the picture tubes. This should be an ITC222 chassis and is a very good set. What needs to be done is several connections and a few parts need to be repaired on the deflection panel. This is the board on the left hand side when rear cover is removed. You need test equipment and soldering/desoldering equipment to do this repair. If you have those things I can help you through the procedure. If not, most tv repair shops can do this repair for between 175-325 for all parts and labor. If it is repaired properly, this set can easily have a 20 year total lifespan so in most cases people decide to repair them. Good luck, Russmann.
Apr 08, 2010 | RCA HD52W59 HDTV Projection Television
What is your opinion about the Craig 15'' high definition LCD TV? Is it discontinued? Is it a decent TV?
I purchased Craig CLC501 from CVS and I am very satisfied. The picture and sound are great. There are many adjustments through a menu but you also can change settings with dedicated buttons on the remote. You can add and delete channels for easy channel surfing. The tuner does a good job picking up week signals with an antenna. It has a QAM tuner for HD channels on cable systems. The inputs on the rear are HDMI, YPbPr, S-VIDEO, VIDEO, RCA AUDIO R/L, PCAUDIO, VGA Port. It has a headset output jack that can be used for external speakers. The 12 volt input accepts the universal power supply for use in an auto.
Oct 13, 2009 | Televison & Video
Mitsubishi WD 62725 -picture slightly tilted from right to left
Thats a common adjustment called the TILT adjustment. You can get the service manual emailed to you from the following link which will explain how to doo the Tilt adjustment. Heres a link to the proper manual for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/wd52525-dlp/cName/mitsubishi
Jul 12, 2009 | Mitsubishi WD-62725 62" Rear Projection...
The screen tilts to the left
The coils on the yoke that control the CRT must have shifted in order for the display to be tilted. A rare thing. You will need to take it to a competant tech to realign the coils as there are magnets and shims that all work together to get the picture to come out right and it is tricky to do.
Hope Ya Fix It!
Feb 01, 2008 | Sharp 32SF560 32" TV
Screen Issue when HD Satellite Receiver is set to 1080i
these tv's are absolute garbage. Ours does the same thing with hi def.
never again for a samsung
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Tv screen is tilted
due to shifting your deflection coil has tilted.
small discolored spot on the screen is also due to same thing.
it is better to call tech to do it right though it is minor work but skill is required.
good luck.
Oct 17, 2007 | Sanyo DS24425 24" TV
Tilted tv screen
The complete convergence for the Philips projection sets usually requires a clear plastic overlay which fits over the screen and has many precisely spaced black dots. The remote is then used to enter the service mode and converge all 3 colors onto the dots, and then the settings are stored in an EPROM IC. This should only be done by someone with experience with the Philips sets.
Jun 25, 2007 | Philips 55PP9363 55" Rear Projection...
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Screen Tilted and Convergence Off
dawgs79. I have the pdf files for the tv. I own the same one. I can send then to you. It shows the factory settings etc ans how to adjust it.
Aug 30, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
