Question about Canon imageCLASS D320 Digital Copier
Copier cuts off sides of page
When copying at 100% it cuts off both sides of the page
5 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: 7x9 copies getting cut off on right side of page.
Have you tried to make a copy by using the by-pass tray or manual feed tray. If the copies come out OK then the problem may be that the paper tray guides are not alined crrectly for the paper you are tring to use.
Posted on Apr 02, 2009
xptareq2000
  • 1447 Answers
SOURCE: Canon image D320 copier doesn't copy entire page
Dear sir,
its problem copier fuser unite
fuser cover is broken .Change it near by copier expert and then solve your problem
Posted on Aug 16, 2009
  • 11 Answers
SOURCE: COPIER IS NOT COPYING; BLANK PAGE IS PRODUCED...
you will chek the transfer corona unit and the bise conecting from the developing area or from the cartradge if thire is no contact point of bias the blank copy will be ocure and if you are not solve you have to chek the high tention voltage from the primery corona or transfer or bias
Posted on May 23, 2010
  • 122 Answers
SOURCE: When I copy a document that is written from top to
enter additional functions; on screen, select copy settings>auto orientation>off.switch off the machine and re start.
Posted on Feb 11, 2011
Aficio 1015 Ricoh copier;page margins changed without instructio
Check the print/copying area to see if those controls have been handled or not. Also remove the wire mesh through which the toner passes through. Clean it well but very gently using a painting brush and a blower. Rest it and try a copy....................sodeep
May 04, 2009 | Office Equipment & Supplies
Apr 01, 2009 | Canon imageRUNNER 5000 Copier
Cuts off left hand few letters in a word
Either put the paper closer to the other side of the glass, or go into the settings to see if it is copying or scanning at 100% See if gives you the option of stretch or shrink to paper size. Also, see if it says Crop Automatically versus copying or scanning entire glass. If there is a choice between Automatic, Home Mode, or Professional Mode, try each one. There is always a reset button to return to original defaults. If you are given the option of seeing a preview first, always do that, even though it takes a little longer.
Aug 06, 2008 | Dell A960 All-In-One InkJet Printer
Partial print
Are you sure you have the paper aligned correctly?
should be left top or center.
Do you have the correct sive paper (Letter instead of A4)?
What happens to the rest of the copy : cut off, blank, black?
Is the scanner light staying on when scanning the whole page or does it die out when it scans 3/4 of it? ( bad scan cable or board)
Jul 31, 2008 | Sharp AL 800 Copier
HP PCS 750 cuts off bottom of 8 1/2 X 11 page when printing. Auto reduces page.I need 100%.
The PSC 750 cannot print a full borderless page, it requires a bottom margin of 0.46", a top margin of 0.08" and side margins of 0.25" when printing on 8.5x11 pages.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jul 04, 2008 | Office Equipment & Supplies
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Jun 10, 2008 | Canon imageRUNNER 5020 Copier
Lost book and stuck on settings
What is normal to you? Don't you want the copy to be at a 100% the same size? Did someone panick botton push??? Let them undo what they did. What dose 100% instred of normal?
May 14, 2008 | Canon PC-D320 Copier
When I want to copy a page it cuts off about 1 inch on th e side Have tried everything I put it on the glass like it says and no luck
i think all printer with copier have in common in regard with copying the have all allowance i think its half an inch so if you copy a borderless document its not 100percent copied theres a cut on the side. My solution? scan and edit so you can have a complete picture without a cut.
yours,
alecz
Apr 23, 2008 | Office Equipment & Supplies
My margin gets cut off on one side whenever I make copies
Are you copying onto the same size of paper or onto another size like A4? If changing size you will have to tell the machine what sizes are in use.
If you are using similar sizes, try setting off a stack and as the machine feeds a sheet in, turn off the power. Lift the lid and see iff the page is running in the correct position and not off to one side. If the page is off to one side, you need to check that you have the paper guide (where fitted) pushed up to the correct position etc.
Let me know if this helps any.
Oct 11, 2007 | Office Equipment & Supplies
Canon imageCLASS D320 Digital Copier Logo
23 people viewed this question
old marine
old marine
