Question about RTO Sole F83 Folding Treadmill
Sole treadmill squeaking - RTO Sole F83 Folding Treadmill
Sole f63 treadmill squeaking with or without person on deck when incline goes down
There is a wheel loose and rubs against something in tat position...
Jan 06, 2018 | Exercise & Fitness
My sole F63 treadmill squeaks when inclining from 0to5. It makes no noise after that, or coming back down.
Please LUBE very the shaft motor, with Grease.
and RUN again.
Otherwise the ball bearing inside is Defective and repair.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Treadmill Repair Incline Motor Lubrication
Nov 25, 2017 | Exercise & Fitness
Sole F-85 treadmill E-5 error
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Sep 27, 2016 | RTO Sole F80 Treadmill
Treadmill squeaks when running
have you lubricated under the running belt ?
Dec 31, 2014 | Sole Fitness F63 Treadmill
My sole F63 treadmill is stuck up in the storage state. I tried to use the yellow lever and it isn't lowering and I can not use it!
Lift the treadmill slightly to take pressure off of the locking pin as you work the release lever.
Oct 08, 2014 | Sole Fitness F63 Treadmill
After putting together my sole f60 treadmill the display wont turn on, it gets a clicking noice, connections are connected. any idea where to start
Hook up the main harness . Make sure you didn't plug one of the connections up backwards. Hooking them up backwards will cause the incline to go all the way up and the display will not come on.
Aug 10, 2014 | Sole Fitness Sole F60 Treadmill
Sole F85 treadmill fan and hand controls not working
There may be two problems, however, I would suggest you replace the main display pcb. That will fix the fan problem. If the handle bar switches still do not function replaces the switch and wiring.
Jan 30, 2013 | Sole Fitness Sole F85 Treadmill
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
RTO Sole F83 Folding Treadmill Logo
Top RTO Exercise & Fitness Experts
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
