Question about Orion StarBlast 4.5 EQ (267 x 114mm) Telescope
Moon wont focus - Orion StarBlast 4.5 EQ (267 x 114mm) Telescope
We have a celestron 114AZ telescope. we cannot see anything with it. why?
Most problems will be overcome by reading and absorbing the instruction manual.
Assuming the telescope is in good order, it must first be pointed at a light source using the spotter scope and then aligned using the lowest power eyepiece before fitting the high powered eyepiece...
You also should be in very low light conditions.
May 28, 2017 | Celestron Optics
How to shoot pictures of the moon
About this result
How to photograph the supermoon: an easy way to shoot moon ...
www.techradar.com/.../photography.../how-to-photograph-the-moon-an-easy-way-to-...
  1. Cached
4 days ago - Taking pictures of the moon is one of the more popular subjects in night photography - but it's also quite tricky to get right. Use this tried and ...
How to Photograph the Moon - Photography Life
https://photographylife.com > Photography Tutorials
  1. Cached
  2. Similar
Jun 11, 2015 - Aperture: Set your aperture to f/11. Shutter Speed: Set your shutter speed to 1/125 on cameras with base ISO 100, and to 1/250 on Nikon DSLRs with base ISO 200. Lens Focus: Set your lens to manual focus (either through a switch on the lens or on the camera) and set your focus to infinity.
How To Take Stunning Pictures Of The (Super) Moon :: Digital Photo ...
www.digital-photo-secrets.com/tip/779/how-to-take-stunning-pictures-of-the-moon/
  1. Cached
  2. Similar
Aug 7, 2014 - Start with ISO 200, f11 aperture and 1/125 second. Try a test shot. Then use trial and error by changing the shutter speed until you can find the best exposure that works for your composition without overexposing the moon. Turn off auto focus.
How-To: Photograph The Moon ' Popular Photography
www.popphoto.com/how-to-photography-moon
  1. Cached
  2. Similar
4 days ago - Planning is a big part of all photography, and shooting the moon is no ... that much money on a lens like this to take impressive moon photos.
How to shoot pictures of the moon Google Search
Nov 15, 2016 | Cameras
How to focus on the moon
Raymond, Telescope aiming and focus instructions. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Use Telescope
http://members.iinet.net.au/~champas/pdf/tips/how%20to%20use%20your%20telescope.pdf
Adjusting your telescope
Jul 21, 2016 | Optics
Cannot focus on moon with Fuji HS30.
I suggest trying a higher ISO setting and using the tripod. My moon shots look just fine from the HS30exr.
Jan 05, 2013 | Fujifilm Finepix Hs30exr black Digital...
I dontknow how to look through it andfocus on a star,or moon
Hi Joe, I'm Mark.
The small scope on top of your big scope is called the "finder" scope. Probably 2X or 4X. It should have cross hairs in the view. Find the moon with it. It will also require focusing but since the moon is bright, you can get an idea where it is in the lens by that.
Next. Find the LOWEST power eyepiece to insert into the lens holder. And rotate the focus knob.
Hopefully, you will see some bright blurry thing and then you can focus on it.
After you get it in focus, put on a more powerful lens and look at the craters on the moon.
Note: You will need to adjust your telescope to the earth's rotation. Your scope should have
instructions for accomplishing this.
Hope this helps,
Best, Mark
Dec 28, 2010 | Tasco 200x50mm Refractor Telescope
I cant get focus on the moon with my 100-400mm lense
Many cameras have trouble focussing on something as far away as the moon. Try manual focus. Also, watch your exposure...the moon is brighter than you think.
Nov 04, 2010 | Cameras
Can't get the moon in focus.
Full moon is very bright, so you are probably seriously over-exposing your image......not enough contrast in there for the camera to focus on.
Under expose in small increments until the camera can latch onto to the image accuratley.
Oct 04, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Telescope will not focus on moon,stars etc. will focus on ground targets. i know there are 3 different optics and i know there use.are there up grades to make this new telescopes work? i e-mailed tasco of...
You won't get anything from TASCO - these are considered toy telescopes. Put the eyepiece with the LARGEST number written on it into the telescope. DO NOT use the 2X barlow it is useless in such a small telescope.
Your first target should be the moon -- practice focusing on the moon until you can do it easily.
Jul 06, 2009 | Optics
Fuji s700 taking good moon shots
shutter speed 50 to 80 ISO at 64 get your apature as small as it will go lagest f number set your focus to single point and single focus if you feel comfortable useing manual focus it is better but my manual focus stopped working here is the link to one of my moon shots on flickr
http://farm3.static.flickr.com/2516/3966267384_90afc0b269.jpg
Jun 23, 2008 | Fuji FinePix S700 Digital Camera
Orion StarBlast 4.5 EQ (267 x 114mm) Telescope Logo
Top Orion Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
deton8 von Splosion
Tony Parsons
Tony Parsons
Are you an Orion Optic Expert? Answer questions, earn points and help others
