Question about Estate Washing Machines
Whirl pool wont run wash cycle - Estate Washing Machines
onthejob5130
  • 640 Answers
SOURCE: whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Posted on Dec 25, 2008
localwonder
  • 6784 Answers
SOURCE: Our Whirl Pool Washing Machine won't drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Aug 15, 2009
SOURCE: My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Posted on Dec 24, 2009
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
rickead1
  • 1998 Answers
SOURCE: i have a whirl pool duet washer with error code
try this:
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Posted on Apr 29, 2010
Clutch for whirl pool 5 speed 9 cycle top loader washer
only available from a whirlpool service agent spares or from the whirlpool parts web page
Feb 06, 2017 | Whirlpool Washing Machines
Whirl pool washing machine doesnt spin dry
If it wont spin at all, check the lid switch. If it will spin but not fast enough to spin the water out of the clothes, it sounds like the clutch could be slipping.
Aug 08, 2010 | Whirlpool Washing Machines
My whirl pool 1400 has stopped working the
Them washer are what you call high efficiency washers.HE. They only use 1 gallon of water to wash them clothes. You go adding more than a teaspoon of soap and that washer is gonna have a cow. Over a period of time that soap gonna build upb50e111.jpg so much the washer is gonna just give-up the ghost. If you know you use the correct amount of soap there could be something in them pump.You need to remove the service panel41b08ad.jpg and take a looksee at that tech sheet and see what it say about them light flashing. While you at it you may as well remove that cap6349b09.jpg and clean out that filter. d081835.jpgThat might put yall back in business. That tech sheet will be in there by that white box which is the motor control unit. The other stuff that the tech sheet error chart might reveal is located on the topside.539a7ad.jpg Good luck on dat repair mon ami.
Jun 06, 2010 | Washing Machines
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Dryer does not go past wet cycle
if your vent hose is clogged, your element most likely burnt open
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool washer bangs when in spin cycle
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
F1 code
well they refuse to adress your issue under a warr. beacause of age , but im certain that a whirlpool auth. servicer will glady adress your issue. As for the F1 generally relates to a faulety control board. but would want( a serveicer ) to check in more detail before jsut askin you to replace the board
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
13 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
