Question about Samsung CLX-2160N All-In-One Printer
Samsung CLX-2160 all colours pale / light / fade.
All cartridges are new. One set of cartridges have been printed with this printer. No other parts renewed.
Niraj Limbu
  • 183 Answers
SOURCE: Hi I have a CLX-2160
sir,
please visit following link:
http://www.fixya.com/support/t718711-faded_print_quality
because you have similar problem with your printer so.
thanks for posting on Fixya!
and rate all answers.
Posted on Feb 11, 2009
Arius
  • 446 Answers
SOURCE: Samsung CLX Printer printing unevenly
it is possible that this is a fuser prob, fuser works applying heat and pressure, if the roller, either the pressure roller or the fuser roller is defective this is most likely will happen too, you might want to  check the number of copies or prints made
Posted on Mar 22, 2009
SOURCE: Samsung CLX-2160, keep getting faded
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
Posted on Jun 30, 2009
SOURCE: I can't print from Internet Explorer 7 with my samsung clx-2160
Hi you've probably worked this out long ago but it's not the printer that's the problem, it's IE7. You need to right click on the IE icon on your desktop and click 'run as administrator'. There are other settings in IE7 that you can change as well if this doesn't work.
Posted on Jan 31, 2010
  • 113 Answers
SOURCE: Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Posted on Apr 19, 2010
Samsung clx 3185 printing is all faded, colors and black
When you go to print, your printer driver should have quality options. Make sure you're not using "economy" or "draft" mode. Try "quality" mode.
Jan 19, 2015 | Samsung Office Equipment & Supplies
Hi, I have had my CLX-2160 printer for 3 years now and its started to print with a fade on the left side only and have just under half black ink left. Is it worth changing the black toner cartridge or does...
Hello.
There are two reasons the fade happens. Running out of toner and the drum not responding correctly. The Drum is the unit that transfers the toner to the paper. if it gets damaged or dirty inconsistent print is usually the result. Try taking the toner out, shaking it and replacing it to see if it affects the print quality. if it does not price a replacement drum and toner, compare it to the price of a new printer and this will answer the second part of your question!!!
I hope this helps Regards GM
May 27, 2011 | Samsung CLX-2160N All-In-One Printer
I have a Samsung CLX-2160 print. It says "transfer
Try this steps it might help,
1. detach the paper tray and push it back correctly.
2. open the front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and in the left side of toner unit there is a sensor door, behind that door there is also a light sensor bulb, which needs to be cleaned by a cotton bud.
Please rate this solution if found useful.
Thanks
Jan 17, 2011 | Samsung CLX-2160N All-In-One Printer
I have a samsung clx-3160fn printer. All toners are ok, espcecially the black one - BUT when I print black&white doc, it is comign out really faded - as if the black toner is low. BUT it is not!! ...
Go to printer properties and check whether you have selected print in grey mode and also check whether you have selected the economic mode. Rectify the same will solve your problem.
Revert back for more assistance.
Jan 31, 2010 | Samsung CLX 3160fn All-In-One Printer
Laser printer samsung clx260 prints pale black
please check cartridge and your printer settings.
Dec 06, 2009 | HP LaserJet 4100 Printer
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Mar 22, 2009 | Samsung CLX-2160N All-In-One Printer
Samsung CLX-2160N All-In-One Printer Logo
32 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
