We have mitsubitshi mr slim air conditioners one of the units has what appears to be mold inside the unit. one repair man wnat s to take the unitis off and clean them out anotjer says he would spray chemicals into them but not take off the unit one says this condition is typical- the other syas it is not I don't know what is best
  • 148 Answers
It is not always normal but it does happen and there is a chemical that can be spryed right into the coil and pan that is very affective not necessary to pull off the unit
Posted on Jun 21, 2009
How does one access the drain pan in a Mr. Slim? I think I have stagnant water (minimally), mildew or mold somewhere and nee to make sure.
POUR some strong bleach water in it where you saw the second guy put water in . that should kill any bacteria if there is any
Aug 06, 2015 | Mitsubishi 9000 Btu Mr.slim Ductless Mini...
Black mold inside unit, fan becoming noisy, I have a hunch that it,too, is covered with black mold.
It sounds like you know the problem and the sollution is to clean it. these system require rutine cleanings every 6 months because they have condensation always in the pan
Aug 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Eo error code indoor unit runs 2-3 seconds then gives eo error code problem started when mr chipmunk chewed mr slims 12 volt wire connecting to out door unit and shorted it . Outdoor unit has bad control...
You need a professional here. Once this has been repaired, I would suggest running the wiring to the outdoor unit inside some sort of piping to protect it.
Jul 20, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
May 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mold inside the home unit
You can use a spray bottle with 100% bleach in it to kill the mold. After spraying the gunk, you can put on some rubber gloves (those dishwashing ones are a good choice) and use some paper towels to wipe up as much of the mold as you can reach.
Spray more bleach on the parts you're cleaning to keep sanitizing the A/C unit and wipe everything dry. You should put all the stuff you used for cleaning it up (paper towels, gloves, etc.) into a plastic trash bag,
I'd also recommend that you do this when any small children and pets aren't in the room you've got the A/C in, and also wear a face mask to keep from breathing in anything that could cause a respritory ailment.
You can also use some Lysol disenfectant to give the whole unit a nice going over, once you're done, to be sure that you've killed any active mold spores. It might be good to give the unit a once-a-month cleaning to prevent the growth of mold in the future.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mold inside unit
There is a product on the market that will prevent mold from growing in your air conditioner.You should be able to find it at a refrigeration supply house.Just take the product and place it in the area where the water collects.There is also a product to help you clean your unit of contaminants on the heat exchanger surfaces.It simply sprays on,and can be later rinsed off.Its usually a straight forward matter to remove the cover from an air conditioner.Usually no more than 4 screws.Some units will slide out of their covers,after removing the screws that keep them locked in place,and some covers simply lift off from the rest of the unit once the screws are removed.In either case the rest of the unit minus the cover will remain intact,and can be cleaned.Cleaning the unit will almost always make it work better too,so your killing two birds with one stone.
Jun 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Water leaking at front of condensor ( inside)unit.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
Jun 12, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr Slim how to clean mold
The best thing you can do is to mix a 1-10 clorox water mix and spray it down with a spray bottle...thta will kill and control the mold. a few days later rinse again to wash the **** down the drain.
heatman101
Aug 31, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim MSY-A17NA noisy interior fan
If the inside fan got loud because it developed mold, the only cure is to keep cleaning it.
Jul 12, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
