Km-1840 c4000 service code - Office Equipment & Supplies
2 Suggested Answers
oxenmonz
  • 21 Answers
SOURCE: Hi! I've got a KM 1650 it boots up then it say ready to copy after few second now printing then C400 error occur please help. kyocera KM 1650 error now printing then c4000 error comes up
c4000 polygon motor sychronize error, try to cleaning polygon, if not effective, need to replace new polygon.
Posted on Nov 05, 2012
Testimonial: "thanks it help alot"
ERROR C4000 IS DISPLAYING HOW TO CLEAR
This error code due to laser unit problem
May 21, 2015 | Kyocera Mita KM-2050 Printer
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
How can i fix km-2035 error c4000
c4000
The Problem:
signal turning on
Causes:
terminals.
2-Defective polygon
motor.
Replace the LSU.
3-Defective engine PCB
Replace the engine PCB and check for correct operation.
This wat the service manual say about this error code but as Tech i recommand for you to do this steps before changing any part and this 60% could fix your problem.
First of all open the back of your machine and make sure there is no cable connector is lose, specially those cables that connected to motors, unplug those cables and plug them again, also make sure that the paper fader cable is connected well. after this put the machine on and off and do this steps:
In the operation panel hit 1087 twice, and this will take you to maintenance mode , then select 906 and hit start, look for the words in the screen, hightlight it and hit start again, the machine may be will tell you put the main power off and on, do this and you will be ok.
hope it helps
May 29, 2014 | Kyocera KM-1510 Copier
Code c4000
C4000 Polygon motor synchronization problem
signal turning on.
Poor contact in the
terminals.
remedy or replace the cable.
Defective polygon
motor.
Replace the LSU.
Defective engine
PCB.
Jul 10, 2013 | Copystar CS-2050 All-In-One Printer
Error c4000
This error code means laser unit has the problem.polygon motor inside the laser unit has problem. am sure if you change laser unit machine will work.
Jan 14, 2013 | Kyocera Office Equipment & Supplies
Error code sc621 how to fix?
do service and be sure to reset the devise after.
May 22, 2012 | Ricoh Aficio MP-C4000
Error code C4000 For a Copystar CS2050
it's mean's laser problem need to change it
May 07, 2010 | Copystar CS-2050 All-In-One Printer
Copier says to Call for service. Code on copier is C4000
cannot clear this message until you have the laser unit repaired or replaced. then code will clear when powered up.
razors
Dec 02, 2008 | Copystar CS-2050 All-In-One Printer
13 people viewed this question
jasbo
jasbo
