Question about First Alert SA302 Dual System Smoke Detector
Carbon Monoxide wired to the house, no battery, beeping
The light is still green, which it says means it is safe, but it beeps twice every few minutes like a smoke alarm does when it needs batteries. There is no battery in it though!
  • 105 Answers
The batt is used for backup. Its beeping to get you to install a batt
Posted on Jun 18, 2009
Kiddle smoke and carbon monoxide alarm that talks 3 of them one ine bed room one in kitchen. Last in basement wired.
All smoke detectors have a 9v battery in them. Try swapping the battery to see if it clears the beeping.
Feb 01, 2018 | Refrigerators
My firex smoke and carbon monoxide alarm 7000 keeps beeping twice every 30 seconds. What does that mean?
Carbon monoxide alarms have a fixed life span. When it is time to replace them they start beeping. This is a safety feature because the sensor loses sensitivity as it ages and it may not go off when it is supposed to.
Jan 11, 2017 | Home
My camper has been in storage for 2 months. The carbon monoxide detector beeps every 30 seconds. I pushed the reset button and it does no longer beep. Is it still safe to use this detector?
Dale, My alarms beep like that to warn me of batteries needing replaced. What I do is hit the test button and ensure it sounds. I would still replace the battery(ies) and retest when you do.
Mar 07, 2015 | Kidde Carbon Monoxide Alarm Model Kncobb
What does code 97 mean?
means you got carbon monoxide
Oct 17, 2014 | Home Security
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
Alarm is beeping once every 5 minutes. Detectornstates to see manual but I can't find it
Battery it is low and dying,replace a new set of battery,press the reset button a few mins for a test.The alarm will stop beeping.
May 24, 2011 | Visonic Wireless Carbon Monoxide Detector
My carbon monoxide detector just has one sold beep and is not plugged in.
I assume you mean your carbon monoxide detector has one solid beep, and it is probably an AC unit. It may be safe to assume that it has battery backup if it is beeping without being plugged in.
First, you may replace the battery with a new one, plug it in and hit the reset button. If that doesn't work, you could bring it in to your local fire department to have it tested.
Check the expiry date on the Carbon Monoxide Detector. It should be replaced if it is more than 5 to 7 years old, check manufacturer recommendations.
A replacement carbon monoxide detector will give you the protection you need and peace of mind. Your safety depends on how fast you deal with this issue.
Jul 07, 2010 | Kidde Nighthawk Combo Gas/co Detector
How can I shut off my Kidde carbon monoxide detector when beeping
Here is the link to the manual for your Kidde model KN-COB-LCB-A
Carbon Monoxide Detector. This may help you solve your issue.
You may find more related information on my website. If you need a replacement or you need to add additional Carbon Monoxide Detectors in other levels of your house, you can purchase them here.
This issue should be solved immediately, Carbon Monoxide Poisoning can only be avoided by making sure you have good working CO Detectors in your house, camp or recreational vehicle.
Jul 24, 2010 | Kidde Nighthawk Combo Gas/co Detector
British gas carbon monoxide detector problem
If it is beeping 3 beeps every minute it is at the end of its battery life you can just replace the batteries by prising the cover off carefully.be aware though that the life span guarantee of these is only 5 years.
Dec 13, 2009 | Kitchen Appliances - Others
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
First Alert SA302 Dual System Smoke Detector Logo
1,537 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Dan Apthorp
Are you a First Alert Home Expert? Answer questions, earn points and help others
