Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Broken wire Ionic Breeze Model S1730
Broken wire with beads
SOURCE: Sharper Image GP Silent Air Purifier with Ionic Breeze s1730
i have 2 units, and had this same issue happen 3 times. Tonight it happened with a forth, last time i had to talk to management to get it replaced outside of warranty. Ionic breeze has major quality issues, and I would NOT buy anything else from sharper image. They also reduced the warranty from the original model drastically. for the price these were, they should be covered lifetime to show their commitment to their product. there is also a class action lawsuit against sharper image, for their false claims for the product...i believe sharper image chose to settle.
Posted on May 31, 2008
  • 62 Answers
SOURCE: ionic breeze gp s1730
This goes along with ted-qcom's solution posted Jan. 19, 2008. My Ionic Breeze GP had the same problem. It was the switch in the front that detects when the collector grid is in place.
I found a suitable replacement switch at Mouser Electronics, mouser.com. It is Mouser part # 101-1203-EV. The problem is that the lever is too long, so I cut it with my Dremel cutting wheel before installing.
Mouser also has a similar switch, part # 101-1201-EV on which the lever is the correct length, however it has solder lugs instead of PC board legs.
I ordered both switches and then made my decision about which to use after looking at them. The choices are either cut (shorten) the lever on the 1203 switch or enlarge the holes on the mounting board to fit the 1201 switch. In my judgement it was easier to cut the lever.
The new switch is installed and the unit is working fine again.
$1.24 + shipping for the switch.
Posted on Aug 10, 2008
  • 45 Answers
SOURCE: broken ionic breeze
Try this site to get replacement collection grids.....
They have several different ones listed so I just copied the webpage so you can see which one would be most suitable for your specific model.
http://www.thefind.com/search?query=ionic+breeze+collection+grid
Hope this helps.. :)
Posted on Aug 20, 2008
  • 6 Answers
SOURCE: IONIC BREEZE GP
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You want to take off the screws from both sides but only remove one side.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
ginko
  • 19396 Answers
SOURCE: One of the wires on my ionic breeze quadra broke.
Hi.
I don't know if you still use your ionic breeze.
About Ionic breeze purifier, I want to call attention on the fact that they are not being manufactured anymore because of heath concerns. New model use a completely different technology. Parts are also not distributed anymore.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Posted on Sep 19, 2010
No power is getting to model s1730 sharper image ionic breeze after taking it apart to replace light bulb. Is there a fuse in this model?
yes there is a fuse on the board located at the base of the unit...if that does not fix problem replace unit.. :)
Jun 21, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
I have a Sharper Image Ionic Breeze GP S1730 the inside wire broke on. Does anyone know how to repair it????
One person used piano wire, but the diameter must be right so the cleaning beads can slide up and down on the wire when the unit is turned up and down.
Oct 22, 2013 | Sharper Image Ionic Breeze GP SI730 Air...
I have model S1730, is it possible to replace ionizing wires and where can I purchase such a wire?
I have replaced those wires with chrome plated wire, stainless steel wires and platinum wires. Nothing lasts very long (weeks to a few months). There are no parts available for these machines as far as I know.
Charlie
Jan 07, 2011 | Sharper Image Ionic Breeze GP SI730 Air...
One of the wires on my ionic breeze quadra broke. It is one of the wires that have the glass beads on them that you clean by turning the quadra up and down. Can it be replaced and how? Thanks.
You're probably screwed...
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Dec 02, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Filter for sharper image ionic breeze model s1730
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station.
Jun 22, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Need Blubs for the Ionic Breeze GP
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Item Number: 220444965077
May 24, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Purchase Ionic Breeze #S1730GBX
Here is a link....actually you will need to copy and paste...its all one link....Ebay
http://cgi.ebay.com/SHARPER-IMAGE-GP-IONIC-BREEZE-AIR-PURIFIER-S1730-EXCT!_W0QQitemZ290304206696QQcmdZViewItem
I hope this helps....good luck and thanks for rating my effort.....the Fang.
Mar 24, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic Breeze
Is this the same as a S1730?...if so...
Manual
http://www.ionic-air.biz/sharper-image/Ionic_breeze_gp.pdf
i have posted the website where you can go and download the instructions.. if these don't help please let us know.
Oct 14, 2008 | Air Purifiers
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
73 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
