Frigidaire ac unit model number fra065at7 keeps resetting
I bought and installed the unit today. When first turned on everything starts up fine, nice cold air and all. After a few moments though the units lights will all flash at the same time while it also makes a beep and then everything turns off. Then it kicks back on minus the cold air part. It sounds like the compressor is not starting, because it is not so loud once it starts back up after its little sequence. If I leave it one to see if it ever starts back up again it does not, but it does every few moments go through that same sequence of events. If I turn it off, and leave it off for a while, I can then turn it on and the air is cold again and runs fine, until the dreaded sequence rears its ugly head yet again.
  • Heating & Co... Master
  • 1,919 Answers
I'm willing to bet the unit is not draining properly. Be sure it is level or pitched outside and the water is draining. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Mar 26, 2017
Ice maker
  • 8 Answers
SOURCE: Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Posted on Mar 30, 2008
  • 142 Answers
SOURCE: AC does not cool. Compressor kicks on and off (Humms when trying to start, electrical smell)
There are a couple possibilities:
1. If this is the first time you've started them for the season, one of the compressors might be seized up from sitting over the winter. In which case, new compressor required.
2. If you've just had the compressor serviced including recharging the system, it's possible that the system is simply overcharged. This will stop the compressor from working and giving you the same symptoms as above. If this is the case, you should have the service people come back with some guages and recover some of the refrigerant and the compressor should be fine.
3. If the unit has been sitting and there is a slow leak then there is not enough pressure in the system to allow it to run. The compressor will shut down if there is not enough pressure, but since you say there is a smell, i really doubt this is the case.
Most likely it's #1 or #2 above. If you haven't had it serviced recently, then yeah, it sounds like you're in need of a new compressor.
Good luck.
Posted on Apr 16, 2008
  • 400 Answers
SOURCE: LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Posted on Mar 05, 2009
SOURCE: Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
Posted on May 05, 2009
  • 22 Answers
SOURCE: Loud screeching noise coming from the unit.
A screeching or squealing noise usually comes from the fan motor. There may be an oil port and you can buy a small telescoping oil bottle at a super hardware store or an a/c supply house. Before putting in he oil, remember to TURN OFF THE POWER TO THE UNIT and only use a light squeeze on the bottle - over oiling will cause a mess inside the motor. It may be a sealed motor and no oil ports. In either case, budget for a new motor as if it's to the squealing stage, the bearings are already damaged and it's a just matter of time before before the motor bearings fail. If possible, get oil on the bearings ASAP - and use the proper lightweight oil for made for this application.
Posted on May 07, 2009
Ho wdo I get my small fridge (Frigidaire model no frc05l5db1) to stop freezing everything.
Sounds like the thermostat is not shutting the unit down and needs to be replaced to restore to proper operation.
Aug 21, 2015 | Refrigerators
Ti-36x Solar Scientific Calculator issue: number buttons resetting to zero...
Look in the back of the calculator, some TI models have a pin hole to hard reset the calculator.
Mar 22, 2015 | Texas Instruments - Ti-36x Solar...
Ac unit keeps tripping the reset button
Good Afternoon Friend,
I understand your Frigidaire air conditioner, model# LRA074AT7, which keeps tripping the reset button. I see that it will start up and then trips the reset button after a minute or two. First, be sure the electrical service is adequate for the model you have chosen. This information can be found on the serial plate, which is located on the side of the cabinet and behind the grille. Secondly, be sure the air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Lastly, your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire 6500-BTU Window Room Air...
Motor fan not working
If you clean and reset the unit, and the fan isn't still working, contact Frigidaire to see if you qualify for any assistance or limited warranty. Most of these small appliances do not have replacement parts since they are so small in BTU size.
Aug 04, 2012 | Frigidaire FRA065AT7 Wall/Window Air...
AC does not start
I just bought this unit today an I'm having the same problem as you
Jul 02, 2012 | Frigidaire FRA256ST2 WallWindow Air...
I have a Frigidaire air conditioner. I've never had a problem with it,at all until a few minutes ago. It all of a sudden quit working. I pushed the reset button and tried to push power, but nothing....
First check the outlet the unit is plugged into. It may be dead, due to a circuit breaker being tripped. Also, the interior of the outlet may be damaged or has a loose wire.
If a circuit breaker was tripped, unplug the unit before resetting the circuit breaker. Then plug the unit back in and turn it ON. If the breaker trips again, there may be a short in the AC wiring or there is another electric appliance on that same circuit, that may be causing an overload, when the AC unit is ON.
Hope this helps you to start troubleshooting the problem. Thanks for choosing FixYa.
Aug 10, 2011 | Frigidaire Heating & Cooling
My dish washer dose not start, it keeps yieling "
Hi enasammar, First thing to do is to reset. Merely unplugging the power cord from the wall socket for 4 hours, then power up again.The purposed of unplugging is to dissipitate the stored current in the memory IC thats control the unit to hang up, so it will gone. Take out all inside the unit and clean,then turn on . If still not working give me the model number so i can find the schematic diagram for that unit. Hope it may helps.
Regards: VOTIT
Dec 03, 2010 | Frigidaire Dishwashers
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
