Question about Plumbing
Moen 87500 handle
How to remove handle
  • 374 Answers
SOURCE: moen single tub shower handle insatll
The valve has a faceplate that attaches with two screws and depicts the hot and cold mixing scheme on it. in the center of this is where the valve stem is located. It has a chrome escutcheon that slides into the faceplate and over the stem.There is a small -U- schaped clip that slides into the top of the valve body where the valve stem is seated that retains the valve stem. With all this in place all you have left is the acylic handle that has a unique shape to it on the internal portion that corresponds to the shape and position of the valve stm. Align the handle and stem and push the handle on. A small screw goes into the center of the handle to attach it to the valve stem. LASTLY you should have the acrylic button that covers the screw holding the handle on. All you do is align it appropriately and push the button onto the handle. The chrome handle version is essentially the same but is retained by a small allen screw on the underside of the base of the handle. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Posted on Oct 22, 2008
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
ftw1952
  • 10319 Answers
SOURCE: moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Posted on Feb 14, 2010
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
  • 65 Answers
SOURCE: how to remove the handles,moen,eva,two handles
the small hole underneath handle where you put your hand has a small set screw(alan wrench)-should be able to see hole,loosen and wiggle handle should pop off, spin off packing underneath and pop out stem make sure water is off - whole new stem is cheap
Posted on Jan 30, 2011
How t fix moen kitchen faucet sprayer
Moen Spray Diverter Repair
First, remove head and soak in vinegar. Use toothbrush to remove scale. If this fixes your problem, ignore the following.
To repair your Moen sprayer, first pick up Moen part # 91192 diverter and a Moen #117 spout o-ring set. Remove the cap on handle, remove the screw on the interior cap and remove handle. Your spout can now be removed by pulling it straight up. Here is a pic of the part. Slide the diverter up and off the faucet post. Remove the two o-rings from the post and install only one large one and one small one onto post making sure to grease them with the silicone provided. The other small o-ring is for faucets without the spray. Discard it. Slide the new diverter down onto the post and reassemble the spout and handle assemblies. Make sure to properly engage the flat on the handle into the groove on the retainer nut when reinstalling handle..
Aug 21, 2017 | Moen Plumbing
HOW TO FIX MOEN KITCHEN FAUCET SIDE SPRAYER CLOG
If it is simply clogged, soak the head in vinegar for an hour and use a brush to clean the scale from the spray head.
Instructions if your sprayer has failed:
To repair your moen sprayer, first pick up Moen part # 91192 diverter and a Moen #117 spout o-ring set. Remove the cap on handle, remove the screw on the interior cap and remove handle. Your spout can now be removed by pulling it straight up. Here is a pic of the part. Slide the diverter up and off the faucet post. Remove the two o-rings from the post and install only one large one and one small one onto post making sure to grease them with the silicone provided.The other small oring is for faucets without the spray. Discard it. Slide the new divertor down onto the post and reassemble the spout and handle assemblies. Make sure to properly engage the flat on the handle into the groove on the retainer nut when reinstalling.
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do I remove the handle on Moen 2352 single handle shower
    There is a allen screw under the handle some times covered by a red and blue plastic plug. Removing the allen screw allows the handle to be removed. Hope this helps.
    Bob
    Jul 04, 2014 | Moen 2352 Chateau Single-Handle Shower...
    Leaking CA87681 moen kitchen faucet
    Throw a cloth over the cover to prevent scratching the finish and grab it with a large pair of channel locks and unscrew it.
    Nov 18, 2013 | Moen 7907 Chateau Two-Handle Kitchen...
    The handle seems to be loose because there is a lot of play in the handle befor the stem ingages . Is this normal in the handle
    If it's the one I'm thinking of, remove cap in center, and remove Philips screw, and pull handle off. If you have the hex shaped piece still on the stem, look at underside for an Allen key, set screw and tighten it, and put handle back on.
    Sep 30, 2010 | Moen & Posi-Temp Single Handle Shower Or...
    Moen monticello shower control, remove handle
    If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
    Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
    Moen Posi-Temp Shower Handle removal
    I hate to say this but maybe the inside of the allen screw has been rounded out by a previous worker. You can drill the screw out and replace the handle with a new one. NOTE: Moen replacement parts are not cheap!
    Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
    Moen single handle shower faucet, contstanly drips
    Moen single handle - push pull has a screw beneath the handle cover plate. The Moen single lever handle has an allen wrench screw located under the curve of the handle. Once either one of these screws are removed, the handle should come off easily.
    Once the handle is off, the water must be turned off and then you can remove the cartridge. Some cartridges are difficult to remove and may require a special tool. Most new cartridge packages have information on them to explain how to remove the cartridge.
    Mar 12, 2009 | Home
    Single lever moen shower valve -can't remove handle
    Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
    Plumbing Logo
    24 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
