Question about Canon imageRUNNER 400S Copier
Replacing the Staples
I am trying to check to see if I need to replace the staples. If so I need a simple way to do it.
    President:
  • 1,126 Answers
The copier will inform you when it's out of Staples. To check the staples, open front cover of the finisher (device on left that catches copies) There should be a pictorial diagram on how to remove/install cartridge on inside surface of cover. Page 7-12 of the Copier Reference Guide if your finisher has 3 trays. Page 7-38 of the Copier Reference Guide if your finisher has 1 tray. Hope this helps.
Posted on Jul 09, 2009
Will the Arrow staples # 405 fit into my Craftsman 68464 staple gun ?
thats the picture of the manual staple gun
and the picture of type of staples you want
on the staple box confirms you can use the staples in that
sears craftsman
note the staple has inches and metric dimensions
all you need to check is the stapler eject system is not worn out
or cause a jam as you try to staple
if sticky .. try some sewing machine oil on the stapler workings
Oct 14, 2016 | Arrow Fastener 405 5/16" Flat crown...
Where do I find staples for the above Ace 2025 staples?
Most staple guns accept a range of staples of a standard type available from many different suppliers. It is rare that a staple should be manufactured for the exclusive use of a single staple gun.
First you need to know the sort of staple you need. Unfortunately staple gun manufacturers tend to omit this information from their literature and instead use the part number they have allocated rather than the more universal information of type and size.
Fortunately many nail and staple suppliers catalogues contain useful drawings with sizes so identifying any staple, once it has been very carefully measured, fairly simple.
Apr 19, 2016 | Staples Tools & Hardware - Others
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Replacing staples
On the back there is a small metal piece that is spring loaded push it in and down and that should release it pull it out and slide staples in replace assembly remembering to push in and up to reinstall holder .Hope this helps.
Bob
Jul 18, 2014 | Arrow Fastener T72 Wire & Cable Staple Gun
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
I have tried to reload the stapler but it will NOT staple What am I doing wrong?
1. Make sure you have the correct staples for the machine. This machine requires "standard" staples, which are 1/4" staples.
2. Check the staple cartridge to make sure there are no visible jams.
3. Check the power connection to the stapler. Is it plugged in? Is the plug working?
4. If you continue to experience problems, contact the manufacturer at
1-800-STAPLES. They will replace the stapler if it continues to malfunction.
Apr 18, 2011 | Staples One Touch High Capacity Stapler
How to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Nov 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Replacing staples
If I remember correctly, you open the cover and there should be a release handle, the staple unit will swing/ slide out , gently grasp the used staple cart. and while pushing down and pulling out. Install new staples.
Dec 20, 2008 | Toshiba e-STUDIO 282 Black and White...
Swingline Stapler Staples Only After You Open It Up....
Dec 14, 2008 | Staples Swingline® 36115 Staple Guns Tools...
Canon imageRUNNER 400S Copier Logo
110 people viewed this question
old marine
old marine
