Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Pilot does light but when I turn gas to ON the pilot goes out. Theralcouple replacement?? where can I get one??
  • 29 Answers
Thermocouple.. you can get one at most hardware stores. turn of the gas to the appliance when changing it.
Posted on Jun 21, 2009
The pilot light goes out. When I go to re-light the pilot and turn the temp for vacation to medium the flame goes out again.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Nov 26, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
How do you light the pilot light on the stove? Model 3627391592
A pilot light will be found on natural gas stoves, fireplaces, clothes dryers, water heaters and furnaces. When the gas is turned off, the pilot light will go out on all of these appliances. After the gas is turned back on, you must relight the pilot light before you can use the appliance. Pilot lights are similar so if you can relight the pilot light for a gas heater you can relight the pilot light for a gas stove or any other gas appliance.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions Things You'll Need:
  • matches OR flashlight
  1. Locate the gas valve by following the gas line in the appliance. The gas valve will have a large red button or knob and will be easy to see and will be well marked.
  2. Check for a gas leak by smelling the area close to the gas valve. Listen carefully for escaping gas and do not attempt to light a pilot light if there is a gas leak.
  3. Hold down or press the red button or knob on the gas valve while holding a lit match in front of the opening in the gas pilot line. Continue to hold down or press the red button or knob for several seconds after the gas ignites to allow the thermocouple (the sensor for the appliance's thermostat) to heat up.
  4. Repeat step 3 if the pilot light goes out after you release the button or knob. In most cases, the pilot light goes out because the thermocouple did not have enough time to heat up, so give it a few more seconds.
  5. Make final adjustment of the gas flow to the pilot light by turning the red knob. In some cases, no adjustment other than "on" or "off" will be needed.
  6. Turn on our appliance to make sure the pilot light ignites the main gas flow. Replace any covers or close any access doors to the gas valve.
Hope this help?
Thanks for using fixya.
Nov 23, 2010 | Kenmore Kitchen Ranges
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Pilot light won't stay lit.
Ensure that gas is getting to the pilot , or you may have a devective pressure regulator.
If gas is getting to pilot and pilot is turning off, then you need to replace the thermocouple.
The thermocouple function is to turn off the gas if there is not enough temperature, so to prevent gas leaks if the pilot light goes off.
Near to the pilot light there should a part similar to a small metal tube directly in contact with the flame. Thermocouple is wired back to the gas valve.
When the pilot is on, and temperature is steady, the thermocouple will generate a small voltage that will keep the gas safety valve open. In case the pilot light goes off, the thermocouple will cause the valve to close. When you hold the pilot light button , the thermocouple will normally reach enough temp to keep valve open.
If the termocouple is faulty, it will turn off as soon as you release the igniter button.
Replacing thermocouple is an easy repair.
Call the number listed on the owners documentation to get the replacement part.
Sep 05, 2009 | Imperial IFS40 Deep Fryer
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
getimage_new.asp?id=599586&imagetype=2&noimagetype=2&colorimagesize=2
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
Gas Fireplace pilot light continually goes out
You may have a problem with the flame sensing capillary. It may need to be replaced, or it may need to be positioned into the pilot flame better, or you may need a new gas safety valve. Sometime there is an adjustment screw for the pilot which can make the flame bigger or smaller. If will be on the safety valve.
Oct 14, 2008 | Grilling
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Heating & Cooling Logo
125 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
