Question about Whirlpool Stove Oven Sensor 8053344
Pe error on range - Whirlpool Stove Oven Sensor 8053344
5 Suggested Answers
richroth
  • 9472 Answers
SOURCE: We installed a new control
PE is for program error
Programming Mode: NOTE: The Program Code is located on the Serial Plate on this unit after the word Code. 1. Press and hold the Door Alarm Keypad . 2. Press and hold Freezer Temperature Down Keypad . 3. Release the Door Alarm Keypad and wait 3 seconds. 4. The control will display PE to indicate the programming mode. 5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more. 6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds. 7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press. 8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit. 9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
Posted on Aug 05, 2011
richroth
  • 9472 Answers
SOURCE: p.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Posted on Oct 21, 2012
SOURCE: WhirlPool PE Error
The persistent PE error indicates components failure in Power section (smaller PCB).... Please take it to a competent repairs shop for components level repairs.
Posted on Nov 25, 2015
gopakumarg43
  • 75571 Answers
SOURCE: WHORLPOOL WASHING MACHINE PE ERROR
In my research, the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Posted on Sep 12, 2016
Whirlpool F65 PE Error?
F65 STEAMER TIME OUT REACHED Error
happens if there is no communication between Central Control Unit (CCU) and steamer electronic board. The failure will reset after running the Diagnostic Test Program. 1. Check connections between the Steamer Electronic board and CCU.
2. Check mains supply is in range (90V-132V).
Jan 03, 2015 | Whirlpool Washing Machines
ERROR CODE PE
The error code PE indicates that the half load motor is defective.
Jan 02, 2015 | Washing Machines
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
per https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/408-5--/Whirlpool-PE-PRESSURE-SENSOR-ERROR-Water-level-pressure-switch-error
b2kjqj
Dec 09, 2017 | Whirlpool Washing Machines
P.c.b. not working
Oct 21, 2012 | Whirlpool Washing Machines
I get a PE error code
I get PE error code in whirlpool white magic F65
Aug 12, 2012 | Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Jun 19, 2011 | Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
I am trying to update Pe Design 2.0 to 2.5.
try to uninstall Pe Design 2.0 totally and try for directly 2.5 and make sure of fine installation and have fine
Dec 14, 2009 | Computers & Internet
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
Whirlpool Stove Oven Sensor 8053344 Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
