Question about Rinnai Heating & Cooling
Rinnai rhfe-557ft error 11 - Rinnai Heating & Cooling
SOURCE: Rinnai RHFE 1001FA
i have a rinnai rhfe 1001fa heater and when its real cold sometimes it will shut down all the lights go out and i have to shut it off then turn it back on and sometimes it still wont start and i will leave it of for a day or two then try it and it will work it seems to act up more when its colder i am running it this fall so far no problems this unit is around a 1994 or so and has not given any trouble till this started last winter
Posted on Sep 19, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai RHFE 1004F Error code 49
A 49 error code is caused by the pressure switch either not proving or a bad component. Check the hose attached from the plastic elbow located behind the heater going to a small square pressure switch found inside the heater. It may have come loose or a mouse may have taken a bite out of it. Also while you are behind the heater, pull off the hose that looks like a vacuum cleaner hose and run the heater with it unattached. If it runs, you have a blockage in the vent. If not, take a flashlight and go outside to the vent. Look down the center pipe for any obstructions. If it still does not work, you may need a new pressure switch.
While the front panel is off the heater, cycle the heater to attempt a start. You want to make sure the blower turns. If it does not, check the wire connections to it. You may be looking at a bad blower. If it is turning but still does not start, we are looking at a bad pressure switch.
Let me know what you find, I may have a switch or blower motor that you can purchase.
Posted on Nov 01, 2007
  • 61 Answers
SOURCE: Rinnai Heater 557ft won't stay on!
it sounds like a thermal cut-out switch. check that vents aren't covered?
Posted on Jun 01, 2009
  • 120 Answers
SOURCE: Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Posted on Jul 21, 2010
SOURCE: our RHFE-263FA gives an 11
www.alpinehomeair.com/_.../Rinnai%20RHFE-263FA%20Installation%20Instructions
http://rural-energy.net/catalog/Products/productdetail.php?pro_id=21
www.houseneeds.com/Shop/manuals/rhfe263fa.pdf
www.webbersupply.com/Webberpdf/reference_161_182.pdf
Hi, well this happens when the, thermistor or thermostat is faulty, you need to use these manuals supplied, at the above links.
Posted on Nov 13, 2010
Error Code 11
Ignition Failure. Make sure you have fuel. Look into the window when you try to start to see if you can see the sparking of the iginter. Make sure the flue pipe is clear on both the exhaust and air side. Short of that you will need to get hold of a Rinnai tech.
Tom
Oct 13, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
After being off all summer i click on but it wont fire up i checked for carbon the tank is full i have a rinnai 1004f
Do you get an error code? 11. 12 68, 72, etc. Does the combustion motor come on. You should be able to hear it. Is the exhaust and air pipe clear? Is the air hose hooked to the back of the stove?
Tom
Sep 17, 2010 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error code 12
Three main causes.
Short circuit on the low voltage side of the wiring (12V) This will show as an immeadiate error code 12 befoe the thing even tries to light.
Faulty earth on the low voltage side shows same as above.
A faulty gas regulator or partial blockage of gas supply that allows the unit to fire, but will not maintain sufficient gas supply to keep it alight. This will happen after it has lit, maybe erratically with the occasional error code 11 if you try and re-light immeadiately.
May 13, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Jun 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 error code 11
I had this problem and oops, the gas intake was closed. check the door on the right side of the unit, and make sure the valve is turned to "open" .... here's the link for the online manual if you want it: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf
Oct 04, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Convector 406TR
press and hold the child lock button until it beeps...
Jul 02, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error code "n"
You might try poking through here:
http://www.webbersupply.com/Webberpdf/reference_161_182.pdf
Dec 02, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error code 11 on my rinnai
A code 11 also means that it might not be getting any gas. On thr right side of the unit you will find a small door. open it up and make sure the valve is in the open position. If it is, you should contact your gas company to come and diagnose what is going on. The Rinnai is not a do it yourself fix it type of heater.
Nov 06, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
32 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
